Wiring for jake break on 102A2(87)... Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2005 » April 2005 » Wiring for jake break on 102A2(87) « Previous Next »
LeonBrown
Posted on Thursday, March 31, 2005 - 4:49 am:
Looking for help wiring jake brake on 1987 mci.
can I wire to front electial box for toggle switch and rear juntion box to jake heads without running new wirers from front to back.
I have book but don't understand very good.
Thanks for any help.
lbrown
Posted on Thursday, March 31, 2005 - 10:08 am:
suggest you have somebody do it for you...it's ALOT more complicated than that..also,wires & a switch have to be hooked up to the footfeed...
mclough
Posted on Thursday, March 31, 2005 - 3:49 pm:
you really dont want it on a toggle switch. someone wired mine to the engine shutdown switch and every time i need to use jake i have to hold toggle ,never mind trying to downshift at same time.
mel 4104
Posted on Thursday, March 31, 2005 - 4:53 pm:
how can this be? you wire the jake switch so that it is powered from the shut off switch and this switch is a 2 position switch so that you have a hig- low jake system. you also have the switch that is controled by the clutch bedal on a manual tranny. these control the buffer switch on the govenor to control when the jake operates.
lbrown
Posted on Thursday, March 31, 2005 - 5:05 pm:
It is a automatic,I have diagram from pacbrake and am wondering if I can run power to buffer switch from back of bus and get up to toggle switch with wiring that is already in bus or if I will have to run two new wires in bus.
leon
Ron Walker (Prevost82)
Posted on Thursday, March 31, 2005 - 6:51 pm:
I used the existing wiring in the bus. Try to pick a heavy gage wire
Ron
Posted on Friday, April 01, 2005 - 2:06 am:
I used an existing wire from the rear to the front, and two existing wires from the front to the rear. The current draw is very low, so any existing wire would be large enough.
I also wired one bus using cube type relays mounted in the engine compartment. Need two, one for each bank of the Jakes. Then the buffer switch, the high-low toggle switch and the wires from front to rear only carry less than an amp to energize the cube relay. The relay then provides the power circuit to the Jakes.
lbrown
Posted on Friday, April 01, 2005 - 4:44 pm:
Thanks to all that helped.I finaly got it using the wires in the bus.Now that I went thought it the wiring diagram was pretty clear.I just would compicate things by not understanding diagram.
But I notice that each challenge makes me understand things better.
Thanks leon
