Bendable Molding? Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2005 » April 2005 » Bendable Molding? « Previous Next »
bill chisholm (Billybandman)
Posted on Monday, March 28, 2005 - 8:22 pm:
Has anyone found a molding that is very bendable. I need inside and outside corners
Jim (Jim_in_california)
Posted on Monday, March 28, 2005 - 8:34 pm:
Well Kydex is a thermoplastic that comes in a whole bunch of colors and various sheet thicknesses. About $70 gets you an entire 4ft x 8ft sheet of .060" thickness. At that thickness you can cut it to shape with any decent quality scissors and then mold it to shape with either the most powerful hairdryer you can find, or a "heat gun" - the latter can set wood on fire if you're not careful so you'd be best off making the edge corner on a separate metal table edge or similar.
Once hot it acts like a sheet of rubber, and then hardens again as it cools. People make gun holsters out of the stuff, molding it directly around the piece.
You can get it in brown, but it will definately still look "plastic-y".
Posted on Monday, March 28, 2005 - 8:42 pm:
they also make a 4" mop board made out of a rubber like material I've had a case of it for 20 years...it's still in the box...but probably unknown condition...looks like maybe 100 feet of it...
John that newguy
Posted on Monday, March 28, 2005 - 8:59 pm:
Both Lowes and Home Despot have moulding in the usual
wood designs (ogee, etc) made out of some Styrofoam type
cra/// err stuff. The say it can be painted or stained, but the
piece I tried resisted any oil or water based stain I tried. The
moulding does come in white, oak or pine colors... A little
heat from a hot air gun aids in forming bends...
doctor al
Posted on Monday, March 28, 2005 - 11:58 pm:
Check with capt Ron. He had some kind of bendable trim he used.Wiggle board or something like that he called it.
Alex
captain ron (Captain_ron)
Posted on Tuesday, March 29, 2005 - 1:03 am:
Billy What exactly are you trying to acomplish?
how tight of a radius? and is it going to be L shaped? there is a rubber base board and some other trim peices but have to be painted.
Posted on Tuesday, March 29, 2005 - 5:06 pm:
I am trying to put trim around the ceiling radius of my GMC 4108. I need inside corner type 1/2 - 3/4" This covers the shoddy woodworking where the walls and the bus ceiling meet. Has anyome actually tried heating that faom trim at HD? That would work really well.
Posted on Tuesday, March 29, 2005 - 5:54 pm:
You should actualy be able to bend 1/2 inch to match that radius if you are talking about your partition wals where they meet the ceiling. if not get 1/4 inch and glue it together to match your radius. or 1/8 inch if its still too tight of radius. if your walls are not finished yet you canc glu the material and place it where you want it with wax paper behind it to keep it from gluing in place and use screws into wall every couple inches but under trim to hold it in place till glue cures. or you can make a pattern out 3/4 ply wood to match radius and bend glue and clamp to jig to make trim then route to profile you want.
John that newguy
Posted on Tuesday, March 29, 2005 - 7:57 pm:
Yeah. Heat helps. It's only a few bucks for an 8' section, so it's
no big loss if/when it breaks. It does snap if bent too far! Watch
your eyes.. Try to aim for the cat.
H3 (Ace)
Posted on Tuesday, March 29, 2005 - 11:28 pm:
If you want a boat or nautical look, you can always use a piece of rope! It glues up fairly easy and gives it a finished look without all the fuss! It would be cheap to buy and done in no time. I think it looks really good in the older busses!
Ace
Jason Whitaker (Jeepme)
Posted on Wednesday, March 30, 2005 - 3:53 am:
I too have been looking for flexible corner trim. I need something to trim the paneling around the windows on a 4104. That includes some pretty sharp curves of ~5" radius. I've been searching the net for some type of outside corner, say 3/4" x 3/4" that would take the curve. Probably have to be rubber.
http://www.mcmaster.com has a variety of trim.
a search with google turns up the following:
http://www.ultraflexmoulding.com
http://www.flextrim.com
Either of which should cover about any need you'd have except for the tight corners around the windows. Though I get the impression that it's rather expensive I've emailed them to ask if they have what I need.
The rope idea is one I haven't thought of. Not sure it's the look I want. Gonna keep it in mind though!
Jason Whitaker
4104
John that newguy
Posted on Wednesday, March 30, 2005 - 4:07 am:
Fabric gimp would do also, with some glue..?
Why not square corners around the windows? The frame look
isn't bad when you add the blinds, shades, or curtains inside it.
PVC pipe covered in your favorite material? It bends easy!
Posted on Wednesday, March 30, 2005 - 4:51 am:
I have seen some pics of the frames around the windows. It doesn't look bad. I'm hoping for a simpler solution.
PVC pipe? Who would think of that?
How about copper pipe, polish it up nice and go with brass on everything possible in the rest of the bus? Might look real upscale, then again it might look like a boiler room.
Jason Whitaker
4104
Jtng
Posted on Wednesday, March 30, 2005 - 7:00 am:
"The Boiler Bus"
Posted on Wednesday, March 30, 2005 - 6:39 pm:
Billy a company called outwater plastics that has what you need. it comes in rolls and in many colors including wood grain they have a web site
Bill D-Wis (Billdegroot)
Posted on Thursday, March 31, 2005 - 11:35 pm:
I bent some 3/4" oak cove molding to 6" radius using steam. I built a "steamer" using a piece of radiator hose, a connector/reducer, and a piece of 3" PVC. Use a tea kettle to create the steam.
Posted on Friday, April 01, 2005 - 1:48 pm:
Bill add fabric softener to your water for even better results
Jtng
Posted on Friday, April 01, 2005 - 4:59 pm:
Grreat! Now my woodwork smells "April Fresh".
Posted on Friday, April 01, 2005 - 8:21 pm:
........ what would "Summers Eve" do for it?
Niles
Jtng
Posted on Saturday, April 02, 2005 - 12:01 am:
heh heh heh..
H3 (Ace)
Posted on Saturday, April 02, 2005 - 3:57 am:
Niles is that what you use? LOL
Ace
Posted on Saturday, April 02, 2005 - 4:19 am:
Yeah - ex-wife was a carpenter - she liked workin with wood too - too bad she was a journeyman - LOL - Niles
John that newguy
Posted on Saturday, April 02, 2005 - 4:31 am:
Niles-
Shoulda' joined her union! Coulda' had the world licked!
HAR
Posted on Saturday, April 02, 2005 - 8:42 am:
Bill, How exactly did you bend the wood. You 'steamed' it then nailed it up while still hot? Or wrap it around a form till it dried and cooled?
I've never tried to form wood like this before but the molding that I'm thinking of bending is real small stuff so should be easy.
Jason Whitaker
4104
H3 (Ace)
Posted on Saturday, April 02, 2005 - 1:37 pm:
Niles that's not what I heard! :-)
Ace
Posted on Tuesday, April 05, 2005 - 11:48 pm:
soory I didn't get back sooner but I've been away from the board. After steaming, I bent the wood using a form and blocks to hold until dry. I don't know if it's necessary, but I leave it for 24 hours.
