Phil Smith (63.14.193.197)
Rating: N/A Votes: 0 (Vote!) | | Posted on Tuesday, August 21, 2001 - 4:27 pm: | |
Hi The '318' refers to a Detroit Diesel 8-71N that has N65 injectors and advanced timing. This was a standard configuration for this engine in the many different uses of the engine. The general specs of the engine are V-8, 568 cu.in., mechanical injectors, left or right hand rotation. The Eagle uses right hand engines. Since it was a bus engine, someone has increased it's horsepower to 318 by the injector and timing change. It probably had 265 or ?? before the change.. The actual horsepower is closer to 304 according to the manual.. Good Luck Phil in Az. |
