Square Tubing Jig Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2005 » February 2005 » Square Tubing Jig « Previous Next »
David & Lorna Schinske (Davidschinske)
Posted on Tuesday, February 15, 2005 - 7:19 pm:
We need a good way to bend the tubing for the curves on the Eagle. Someplace, somewhere, I ran across a pic of a homemade gizmo that was used to bend the square tubing. Unfortunately, it's either saved to my hard drive, in TN, or is saved to a CD, also in TN, and I'm in NC. Thanks for the help.
Lorna
Posted on Tuesday, February 15, 2005 - 8:47 pm:
Present your request to Sojourner, He made a bending fixture to change the roof bow attachment to the walls. The device is presently at Jack Conrad's house in Arcadia. I understand that Jerry will be in Fla soon.
Onward and Upward
Jim (Jim_in_california)
Posted on Tuesday, February 15, 2005 - 9:52 pm:
Is it similar to a round tubing polka?
Posted on Tuesday, February 15, 2005 - 10:09 pm:
Thanks! I found the thingy on Jack Conrads photo Album (Sojourner: A Total Transformation) http://members2.clubphoto.com/jack217421/45259/guest.phtml I knew someone here would know where I found it at!
Lorna
Posted on Tuesday, February 15, 2005 - 10:56 pm:
Lorna,
Keep in mind, there's more to it than readily meets the eye from a picture. It's used with a hydraulic press or jack. I think the devise grabs the square tube and rolls or drags it around the radius. IIRC both inside and outside sides of the tubing cross-section [square] deform so it doesn't present the same surface as the hat sections used by MCI for their roof bows, or by a bending machine that used an inner mandrel to preserve cross-section, for example.
Note I said the same "surface" - it's quite workable but I wanted you to be aware up front cuz if you were planning on riveting in the curved area it could present problems.
Onward and Upward
Connel Smalling (Connel)
Posted on Wednesday, February 16, 2005 - 12:27 am:
Purchased one of these on sale from harbor freight & works great. Replaced lots of tubing on my Eagle.
http://order.harborfreight.com/EasyAsk/harborfreight/results.jsp
Posted on Wednesday, February 16, 2005 - 12:28 am:
After Jerry bent the 1 1/2" square tubing for the new roof bows, he welded a piece of 16 gauge by 4" flat stock to the top of the new bows. Rivets will be attached trough this flat stock using buck rivets.
Jerry has not arrived back in Arcadia yet. Not sure when he is coming down. Jack
Posted on Thursday, February 17, 2005 - 8:15 pm:
Connel,
Your Harbour Frieght link doesn't work. What was it that you ordered?
Lorna
