SOLTRON ? Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2004 » October 2004 » SOLTRON ? « Previous Next »
Posted on Tuesday, October 19, 2004 - 1:51 pm:
As most snake oil salesmen have a grand tale ,
is this "too good to be true"?
This CLAIMS that they have bugs, that eat the bugs living at the water interface of diesel and other fuels.
IF it actually works it would be a great aid to RV's that sit far too long far to often.
Soltron™ is a fuel enhancing agent. For maximum effects and value, use Soltron™ in every tank at the rate of approximately one ml per gallon (there are 30 mls per ounce). Soltron™ is pure fuel and will not hurt any engine if overdosed.
16 oz. bottle: Treats up to 500 gallons. Each red line indicates approximately one ounce, or 30 mls. Remove cap and tamperproof foil liner. Pour one ounce into tank for every thirty gallons of fuel. Effects can be felt in as little as thirty minutes.
1 Gallon treats up to 4,000 gallons
5 Gallons treats up to 20,000 gallons
55 Gallons treats up to 220,000 gallons
Special Performance Notes
Smog testing: Soltron™ may be used to pass cars and trucks subject to emissions testing. For most automobiles, regular use of Soltron™ will be sufficient to keep them within their acceptable range. If a vehicle fails, or is expected to fail, run two tanks of Soltron™ treated fuel through the vehicle at freeway speeds, then before the test, add one full 16 oz. bottle of Soltron™ one day before the test. Always test vehicle at full temperature.
Vehicle tank cleanup and rejuvenating stale gasoline:
Soltron™ is a powerful fuel tank and fuel system cleaner. It will also improve stale gasoline. (Up to six months old) Add one 16 oz. bottle of Soltron™ for every 100 gallons of old gasoline or tank capacity to any contaminated tank and allow to sit overnight. You can now use the fuel. Always monitor fuel filters during the first few days after a double dose.
Rejuvenating old diesel fuel: Treat old or contaminated diesel fuel at the rate of 16 ounces per 250 gallons. Circulate for two to three days. Allow the fuel to settle, and remove any water off the bottom of the tank. Diesel fuel is ready to use.
Cautionary Notice
Soltron™ is a powerful dispersant and may loosen heavy accumulations of sludge, including deposits caused by overuse of other fuel additives. Fuel filters may require servicing when first using Soltron in contaminated fuel.
Usual disclaimer , NO I don't own the company.
Anyone have actual experience with this goo?
TWO DOGS
Posted on Tuesday, October 19, 2004 - 2:26 pm:
"effects can be felt" ???????????????
John Rigbyj
Posted on Tuesday, October 19, 2004 - 4:25 pm:
Two Dogs What do you mean????
TWO DOGS
Posted on Tuesday, October 19, 2004 - 4:29 pm:
that is what it says in FF posting (???????)
Gary McFarland (Gearheadgary)
Posted on Tuesday, October 19, 2004 - 4:36 pm:
I see what he is referring to"16 oz. bottle: Treats up to 500 gallons. Each red line indicates approximately one ounce, or 30 mls. Remove cap and tamperproof foil liner. Pour one ounce into tank for every thirty gallons of fuel. Effects can be felt in as little as thirty minutes. "
that's a pretty weird way to say that.
Do you drink it or pour it in the tank?
Gary
Posted on Tuesday, October 19, 2004 - 6:19 pm:
Pour first, drink second - to verify the results!
[Don't do this at home]
LOL!
TWO DOGS
Posted on Tuesday, October 19, 2004 - 6:24 pm:
it keeps ya' regular.....no bran needed....
just wonder how the results "FEEL"...
one company I worked for years ago...had a 10,000 gallon diesel tank for emergency use,in case we lost elec. They found groth in it & sold the contents at a very reduced price
Tony H. (Bluegrass)
Posted on Monday, October 25, 2004 - 7:23 am:
I don't know about this product but I have just come back from a 600 mile trip In my MCI-7 with a 8V71 and before I left I put In BioBor It Is an Algae Eater I got It at West Marine In Sandusky Ohio It made that old 871 run like a new engine and I would have bought the 3 ounces that I put In the tank for the $18.95 that I paid for the bottle that I got If I had known what It would have done
Tony
Posted on Monday, October 25, 2004 - 10:37 am:
After any first Bio Bor treatment , carry a few primary filters , or get the fuel tank sump drained .
