Norcold working ONLY on LP... Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2001 » July 2001 » Norcold working ONLY on LP... « Previous Next »
John L. (24.92.216.50)
Posted on Monday, July 09, 2001 - 5:53 pm:
I have a 2 year old Norcold that works fine on LP but flashes and shuts down when switched to battery or 120v service via the keypad. It all worked great in the past.. any ideas??
Frank Allen (66.26.215.113)
Posted on Monday, July 09, 2001 - 8:32 pm:
There is a electricheating element or coil or whatever you want to call it, id take a volt meter and check to see if it is getting the voltage, you can sisconnect the wires going to it then check accross the coil with a ohm meter, if it shows 0 replace the coil, if its got the voltage present, and the coil is ok it has to work, could be a fuse somewhere blown. see where it feeds from . should be easy TO check out, hope all this helps you out
Frank allen
