Difference between the VH-9 and the V... Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2004 » October 2004 » Difference between the VH-9 and the VS2-8 « Previous Next »
grant (65.73.182.168)
Posted on Sunday, October 03, 2004 - 9:07 pm:
Can anyone explain the major differences between these two transmissions? I have the manual for the VS2-8 and yet the VH-9 appears to be the transmission installed in my bus.
Thanks
jimmci9 (209.240.205.61)
Posted on Monday, October 04, 2004 - 3:30 am:
1 of the major differnces is the shifting between the torque convertor range and direct range... the vh uses an external air shift... the vs2-8 uses an internal oil-pressure type clutch...ive got a vh in an old 5105 gm...
Phil Dumpster (24.17.4.245)
Posted on Monday, October 04, 2004 - 10:50 am:
The VH9 is a bit different from the VH in your 5105. The VH9 dates from 1968 or so through the introduction of the V730.
steve souza (Stevebnut) (24.60.226.230)
Posted on Tuesday, October 05, 2004 - 12:29 pm:
the vh9 is a single speed trany with hydraulic acting as first then torque converter lock acting as second.
The vs2-8 is the same with the exception of a splitter on the input shaft of the trans which gives a third range of overdrive.
Steve
