iowamrert (65.248.192.237)
Rating: N/A Votes: 0 (Vote!) | | Posted on Sunday, October 03, 2004 - 4:53 am: | |
I need to see if anyone else has had this problem! When my air presure starts going down on the bus the washer starts spraying till all air is drained out of my air tanks. Finaly figured out why my washer tank was always emty! Just dont see why it would do this. any ideas would be great. |
Rating: N/A Votes: 0 (Vote!) | | Posted on Sunday, October 03, 2004 - 5:41 am: | |
Duhhh. I have no idea how this could occur. But the only thing that I can think of is the control valve that turns it on must be acting up. Most of these air parts are easily disassembled and cleaned up. I would think that you could either replace the valve or take it apart to service it. Maybe an o-ring is damaged. Good luck. Tom Caffrey PD4106-2576 Suncatcher |
BrianMCI96A3 (67.77.37.160)
Rating: N/A Votes: 0 (Vote!) | | Posted on Sunday, October 03, 2004 - 2:19 pm: | |
Yep, like Tom says, if you can get the washer valve apart clean it up, replace the o-rings in it and you'll likely be back in business. Brian |
