First time pulling a toad didn't go s... Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2012 » February 2012 » First time pulling a toad didn't go so well « Previous Next »
Cory hart (Chart1)
Username: Chart1
Post Number: 92
Posted From: 166.205.12.249
Posted on Wednesday, February 15, 2012 - 5:22 am:
Well I put the transfer case in N along with the transmission and turned the key to the first slot forward (so I thought)! I stopped about 5 blocks from home just to double check all pins and locks and wheels where straight all is good. Next safety check about 8 miles from home that I always stop at for a safety inspection. Glad I did my brand new tires on the jeep where hot and tread tore up from being drug 8 miles with the wheels locked in the 1 o clock position. The key was in the off position. I bet I don't do that again !
Bill Gerrie (Bill_gerrie)
Username: Bill_gerrie
Post Number: 651
Posted From: 216.198.139.38
Posted on Wednesday, February 15, 2012 - 5:35 am:
Cory
Hard lesson learned. Always make sure the transfer case goes into N or it will cost a fortune to repair. Try reving up the motor in N to check it. I pull a Dakota which is the same power train as the Jeep with no problems. I had the steering wheel lock removed by the dealer so no problems now with the wheel being locked. Like mentioned before "don't have any people around when you are hooking up". The best advice you can get.
Bill
George M. Todd (George_todd)
Username: George_todd
Post Number: 1319
Posted From: 76.94.209.14
Posted on Wednesday, February 15, 2012 - 5:50 am:
Cory,
What Bill is saying, is to put the trans in drive with the transfer case in neutral to make sure the case is in neutral. If the engine revs like the trans is in neutral, you're OK.
Remember also that with the transfer case in neutral, PARK doesn't work, the toad is free-wheeling. Make sure your parking brake is released before leaving also!
Another suggestion is to be sure to hook up by driving your toad as straight as you can toward your bus, and depart straight for a few feet at least with the bus, so it doesn't scrub the tires on the toad, and make the steering wheel spin and overcorrect to try and catch up.
G
Larry & Lynne Dixon (Larry_d)
Username: Larry_d
Post Number: 379
Posted From: 50.39.216.227
Posted on Wednesday, February 15, 2012 - 6:32 am:
I always leave the vehicle running while I hookup so all neutrals, wheel lock and safty chains can be checked before engine is shut off.
I also put a knife shut off on battery because the toad was going dead on long tows.
Larry
Username: Jackconrad
Post Number: 1449
Posted From: 74.4.80.12
Posted on Wednesday, February 15, 2012 - 1:04 pm:
Cory,
Transfer case in N, transmission in PARK. This prevents the transmission components from freewheeling and turning without lubrication. As long as transfer case is in N, there is no problem with transmission being in PARK. Check your owners manual. There should be a page specifically on towing your car behind an RV. Jack
Post Number: 1450
Posted on Wednesday, February 15, 2012 - 1:06 pm:
Another thought, I know several people (not me, yet)that removed the sterring wheel, removed the steering lock pin, then re-installed the steering wheel. This definitely prevents towing with wheels locked. Jack
Username: Pd41044039
Post Number: 758
Posted From: 74.212.157.91
Posted on Friday, February 17, 2012 - 4:26 am:
I turn the ignition on, then just one click "off" where the gauges & idiot lights go out. But it is really easy to get something wrong when you get distracted at all. I usually hook up so that I have to turn a left turn when I leave. I watch the toad in the mirror to be sure the wheels are tracking the bus.
Post Number: 1453
Posted From: 75.204.160.175
Posted on Friday, February 17, 2012 - 1:36 pm:
I have a specific sequence I go through when hitching our toad. When hitching, I do not talk to anyone or let anyone help me hitch the toad. This is one task that if done incorrectly can result in very expensive repairs or worst yet, serious injury or death to others we are sharing the road with. Jack
Post Number: 1322
Posted on Saturday, February 18, 2012 - 7:28 am:
Jack is very right!
My uncle left his stick shift toad in gear after he hooked up. The raw gas into a hot catalytic converter set it on fire, and when they saw the smoke, it was too late. They were able to unhook it and save the bus, but the Mazda pickup with 1200 miles on it was a total loss.
G
Username: Chessie4905
Post Number: 2264
Posted From: 71.58.71.157
Posted on Saturday, February 18, 2012 - 2:51 pm:
Years ago, my father hooked his GEO metro up to coach and forgot to take it out of first gear. Someone came up from behind on the road in a couple of miles flashing his lights. Told my dad there was smoke coming out of car. He had been up to 50mph briefly. Had it repaired under warranty. All the valves were bent. Must have turned almost 10 grand. He traded it in on a new one as soon as it was fixed. Needless to say, he didn't make that mistake again.
