Dennis Tracy (Eagle10)
Registered Member Username: Eagle10
Post Number: 37 Registered: 10-2006 Posted From: 198.228.212.191
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, January 02, 2012 - 6:51 pm: | |
Broke down in Willcox, Az. at the TA truck stop. Need a new power steering pump for a 1991 Prevost bus. Any ideas? |
Post Number: 1009 Registered: 1-2009 Posted From: 72.211.145.15
Rating:  Votes: 1 (Vote!) | | Posted on Monday, January 02, 2012 - 6:59 pm: | |
try 520-623-3663 Truck & Trailer Parts in Tucson for the pump. They are 3 blk's from the GRANT ROAD exit on I-10 |
Bob Glines (Robertglines1)
Registered Member Username: Robertglines1
Post Number: 59 Registered: 11-2010 Posted From: 75.205.184.130
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, January 02, 2012 - 8:18 pm: | |
Tracy: if it is just blowing oil out the side--pressure relief valve--it's just a 10 cent o ring. Just happen to me. on the 89 and I thought the worst. Simple drive the pin out and replace o ring on spindle and replace spindle. It is spring loaded but can easily be held in with your finger. remember when your taking it out. good luck Bob |
Post Number: 60 Registered: 11-2010 Posted From: 75.205.184.130
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, January 02, 2012 - 8:22 pm: | |
The o ring that is suppose to be in there is flat. If you need more info call me: 812 449 8263 Bob |
Post Number: 1340 Registered: 8-2006 Posted From: 173.87.191.172
Rating: N/A Votes: 0 (Vote!) | | Posted on Tuesday, January 03, 2012 - 1:58 am: | |
There is a Napa in Wilcox that can get you the Vickers power steering overnight I bought one there before east on 10 from Wilcox is a bus and truck shop the owner has a bus good luck |
Post Number: 38 Registered: 10-2006 Posted From: 198.228.212.191
Rating: N/A Votes: 0 (Vote!) | | Posted on Tuesday, January 03, 2012 - 2:33 am: | |
Thanks for ideas. Brewers Truck Repair is across the street from the TA we are in. They tell me they will install it But I need to get the pump. I checked with NAPA today and they need numbers off the pump. Prevost numbers no good for them. Called Prevost and they wanted $200 fee to do it today as an emergency fee since they were closed. Called Prevost help number and he said Vickers 661006 is what I need. Pump has been growling lately and harder steering. Issue is fluid coming out fill hole back pressure and leaking around the pump itself. |
Post Number: 61 Registered: 11-2010 Posted From: 75.207.8.27
Rating: N/A Votes: 0 (Vote!) | | Posted on Tuesday, January 03, 2012 - 2:53 am: | |
growling is usually air or low fluid--oil out pump is probably out where I told you from o ring. Do as you want. Worth checking out. When you bleed it to to lock hold briefly then to other lock hold briefly then ck fluid. Where the plunger goes in(pressure relief) where o ring if it has been hammering it has worn grove. this lets pressure go down to system. Turn valve 90 degrees and pressure should be restored. or replace pump. |
Post Number: 1341 Registered: 8-2006 Posted From: 173.87.191.172
Rating: N/A Votes: 0 (Vote!) | | Posted on Tuesday, January 03, 2012 - 1:57 pm: | |
You need to replace the drive coupling spacer also if it is gone don't worry about the trash in the oil pan it won't hurt anything good luck |
Post Number: 40 Registered: 10-2006 Posted From: 198.228.215.103
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, January 05, 2012 - 4:27 am: | |
Back on the road again. Mobile service truck came and installed new pump. No more growling and it took the guy 3 hours to do from the back battery compartment. |
Post Number: 1011 Registered: 1-2009 Posted From: 72.211.145.15
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, January 05, 2012 - 6:51 pm: | |
Post Number: 41 Registered: 10-2006 Posted From: 198.228.213.207
Rating: N/A Votes: 0 (Vote!) | | Posted on Saturday, January 07, 2012 - 6:10 am: | |
$120 per hour. 3 hour install. 2. 1/2 hours travel time. Pump $466. Over night parts $135. Misc.$$? Total about $1400 Sometimes you have to pay top $$ if stuck. |
Post Number: 1016 Registered: 1-2009 Posted From: 72.211.145.15
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, January 09, 2012 - 11:27 pm: | |
..well it certainly could have been worse & happened in a worse place... all in all you are out of there, alive & that's one more little thing that ain't gonna bite you down the road . |
