How many gallons Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2004 » August 2004 » How many gallons « Previous Next »
Bob Baldwin (Bob4106) (69.132.84.145)
Posted on Wednesday, August 25, 2004 - 9:05 pm:
Getting ready to change my motor oil and filter in my 4106 8v71 fore speed. How many gallons of oil will I need? All so i'm useing dello 400 40 wt. since thats all I can get now. Can I use this same oil in my transmission too?
FishbowlBrian (Fishbowlbrian) (67.165.212.171)
Posted on Wednesday, August 25, 2004 - 9:31 pm:
Seven gallons for my 8v71. Buy some extra for the road... and fill up the oil filter if it's the spin-on canister-type. Mine held almost a gallon by itself, I think.
Make sure that the Delo 400 is SF-2 rated, because the new stuff is not. I made that mistake before, too, on my last oil change in my last bus (LONG story).
Delo 100 is usually special order, but certain grades of 40wt. Rotella T, Citgo, etc. meet SF-2. I believe you can order SF-2 40wt. from NAPA and have it in a few days.
And, yes, the tranny oil is the same spec. as your engine.
Don't forget the tranny oil filter, too. Inspect it for metal while you're at it.
FBB
eagle (12.220.190.142)
Posted on Wednesday, August 25, 2004 - 10:36 pm:
That is CF-2 not SF-2
Posted on Wednesday, August 25, 2004 - 11:05 pm:
D-oh! I don't know my C's from my S's and there I go givin' advise. And I had to say it incorrectly like four or five times to boot.
Sheesh. Rookies...
What eagle said, Bob. CF-2 is what you want. You'll search long and hard and never find SF-2.
FBB
Posted on Thursday, August 26, 2004 - 1:38 am:
I checked the oil I got. I picked up a case and checked on the gallon jug. all I see is a API CF/CF4 level performance is this the wrong stuff
Deacon (150.199.209.34)
Posted on Thursday, August 26, 2004 - 2:56 am:
Bob, wrong oil, you need a CF-2 oil for the older 2-stroke Detroits. In addition, you need to look for 1% or less ash content.
It might be a little hard to find but your motor will thank you for it.
John F.
RJ Long (Rjlong) (67.181.236.27)
Posted on Thursday, August 26, 2004 - 3:43 am:
Bob -
Deacon's right, you've got the wrong oil. Take it back to where you purchased it and get a refund.
Here are links to several oil distributor locators, where you can find someone in your area to order the correct oil from:
Chevron Delo 100:
http://www.chevron.com/prodserv/nafl/wheretobuy.shtm
Shell Rotella T:
http://www.shell-lubricants.com/distributors.php
Exxon/Mobile XD-3 Monogrades:
http://www.prod.exxonmobil.com/channelpartners/ns_distributor_directory.jsp
Citgo Citgard Transit Low Ash Engine Oil:
http://www.citgo.com/CITGOLocator.jsp
Spend a few minutes on these sites looking for a local distribtor/dealer. I noticed there are several in NC, but I'm not sure which are closer to you. Be sure to order at least two cases, you'll use seven gallons just for the oil change, and they come six gallons/case.
HTH,
RJ
PD4106-2784
Fresno CA
Glenn (166.102.79.23)
Posted on Thursday, August 26, 2004 - 3:58 am:
Bob, here's a couple of links that might be worth reading.
http://api-ep.api.org/filelibrary/ACF28.pdf
http://www.shell-lubricants.com/products/pdf/RotellaTSG.pdf
I've used the Delo 100 SAE-40 and also the Shell Rotella T SAE-40. Both will do, so it'll be a personal preference. Also keep in mind that Texaco makes a good oil too.
I run the Rotella T now because I can get it locally.
Glenn
Stephen Fessenden (Sffess) (65.154.176.5)
Posted on Saturday, August 28, 2004 - 3:56 am:
Rotella is everywhere. I'd use it.
Posted on Saturday, August 28, 2004 - 7:18 am:
All in all your right Rotella is everywhere. Thats what I went with. The 40 wt. CF-2 $44.95 a case, Thanks for all the input
