Injector size 8V-71T Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2004 » October 2004 » Injector size 8V-71T « Previous Next »
Steve Neely (66.225.4.5)
Posted on Tuesday, September 14, 2004 - 1:01 am:
I have a 8V-71T that had problems. After having it pulled apart I found size 80 injectors. Pedco in California built it. The motor has a cracked head and bad rings from over heating. What size injector would be best for long life and OK HP? I don't think it has an after cooler.
RJ Long (Rjlong) (67.181.236.27)
Posted on Tuesday, September 14, 2004 - 2:19 am:
The simple answer to your question:
It depends. . .
What coach is this motor in? A lightweight GMC or heavier MCI, Prevost or Eagle?
Basically, since you've got the engine torn down, here are your options:
~ Standard timing w/ N60 injectors = 275 hp
~ Advanced ("A") timing w/ N65 injectors = 304 hp (often called 318 by the truckers)
~ Standard timing, N75 injectors plus adding a turbocharger = 350 hp
~ Standard timing, 7C75 injectors, adding a turbocharger plus an after cooler (if your block will support it) = 370 hp
Best fuel mileage and longevity will be w/ the N60s, which is what most bus companies used.
How fast you want to go also translates into how often you want to stop for fuel. . .
While you've got it apart, get a Jake brake installed, too. Well worth the extra bucks.
HTH,
RJ
PD4106-2784
Fresno CA
Geoff (Geoff) (66.238.120.69)
Posted on Tuesday, September 14, 2004 - 2:46 am:
Go with N75's. BTW, I was at a MAK Bus Convention a few years back, and one of the speakers at a re-power seminar was Virgil Cooley from PEDCO. I specifically remember him saying that 8V71T's were notorious for overheating the heads, and he recomended going with the aftercooled (8V71TA) engine. Humm...
--Geoff
'82 RTS CA
Dwight (67.213.8.162)
Posted on Tuesday, September 14, 2004 - 4:50 am:
I do not know what kind of H.P. you need but I am running a regular 8v71 with 18.1 compression pistons an added a turbo with out the aftercooler and N70 injectors, have 5000 miles and no overheating problems yet, about 330 H.P.
FAST FRED (4.245.188.247)
Posted on Tuesday, September 14, 2004 - 10:14 am:
"How fast you want to go also translates into how often you want to stop for fuel. . .'
To expand on RJ's correct info, most coaches go as fast as you wish ,on the Level.
The ONLY advantage to hot rodding is HILLCLIMBING.
Sure there will be a slight benifit in all full throttle accelerations ,
but the hills are where you will notice any power increase.
Unfortunatly some left coast hills are LONG , so the hot rod coach will always suffer potental problems with overheating.
Overheating is the easiest way to KILL any DD.
$10-$14K rebuilds for 10 min, "Saved"?
Caviat Emptor,
Marc Bourget (209.142.38.81)
Posted on Tuesday, September 14, 2004 - 2:17 pm:
More like:
Caveat Stompor (too much foot in the throttle)
Caveat Non-shiftor (Too high a gear)
Even a hot rodded coach will survive if a prudent driver will take away some foot and a gear,
But then the speed parts are simply a waste of money to match the extra fuel going out the tail pipe!
Onward and Upward
John Rigby (65.112.227.94)
Posted on Tuesday, September 14, 2004 - 3:27 pm:
I agree with FF. As those left coast hills have got me twice. Not to the tune of $10k but two cylinder head gaskets on my 671 in the last 18 years.Hopefully my new rad core has put an end to that.
John
John Rigby (Unregistered Guest)
Posted on Sunday, October 17, 2004 - 1:28 pm:
Just checking to see were and how this would appear.
