nelson Thomas (205.188.116.136)
Rating: N/A Votes: 0 (Vote!) | | Posted on Saturday, July 17, 2004 - 2:50 am: | |
I was at a local car show and one of the vendors showed me an item called a pulse generator that screws on to the old sender on the transmission. It sends an electric pulse through a wire to the speedo. To calibrate it you find a mile marker, punch a button then punch another button at the next mile marker. My transmission seems to have the necessary driver. Has anyone used this system? How well does it work? I like this idea better than the system that has a pick up sensor on the front brake drum that seems to loose contact after awhile. Nelson, Knoxville TN. |
Frank Allen (64.12.116.135)
Rating: N/A Votes: 0 (Vote!) | | Posted on Saturday, July 17, 2004 - 3:22 am: | |
I have used the type you speak of and it worked ok but would be a lot harder to install on a rear engine bus if thats what you have, mine has the sensor on the wheel, it is a dixson and ive never had a problem with it, also has a odometer which i like since some butcher in VA worked on my bus and destroyed the hub meter and the differential and helped me waste 2000.00. Frank Allen 4106 |
TWO DOGS (63.185.65.5)
Rating: N/A Votes: 0 (Vote!) | | Posted on Saturday, July 17, 2004 - 5:07 am: | |
ALL the big trucks have the left front wheel as a sending unit...there are thousands ,think I'd stick with that,just an opinion |
Craig Craddock (66.82.9.59)
Rating: N/A Votes: 0 (Vote!) | | Posted on Saturday, July 17, 2004 - 6:21 am: | |
I have used one in my 04 for nine years now. No problems, also have a friend with one. I used one of the original wires already marked for the speedo between the front and rear electric lockers. I also needed a ground and a positive wire at the front and rear. I first used it with the spicer and later with a V730. It took a couple tries to get the calibriate right on. Using measured section mile markers and later checked with radar to verify. I used 3 miles at a time for greater accuracy. A speedo shop can use a counter to count the pulses in a measured mile and then simply set the dip switches per enclosed directions. I am also using a pulse generator for my tach. Look at Datcon.com for one mfg. Products and then Heavy Duty Industrial. Not the only way -- works for me. |
BrianMCI96A3 (65.160.214.236)
Rating: N/A Votes: 0 (Vote!) | | Posted on Saturday, July 17, 2004 - 3:19 pm: | |
I have quite a bit of experience with a company called Nu-Metrics that manufactures Distance Measuring Instruments, for our DOT vehicles. They also make a pulse generator that screws onto the transmission like the type Nelson mentioned...and they make a sensor that can work with the original vehicle speed sensor(if it has one and it's woking still), that has dipswitches like Craig mentioned. These devices, along with a NS-50 "head" unit, are accurate enough to measure within plus or minus one foot over a 4000 foot distance PLUS give distance traveled, miles per hour and have a bunch of nifty features including things like Interval Measuring, plus a choice of Miles or Kilometers or Feet. Very accurate, very reliable, if the vendor that Nelson talked to has a product that is remotely similar it is a good product. Brian |
Craig Craddock (66.82.9.48)
Rating: N/A Votes: 0 (Vote!) | | Posted on Saturday, July 17, 2004 - 4:40 pm: | |
PS: I know they will work with a negative ground.If someone has not changed your 4104 over from the POSITIVE GROUND check and see if they will work still work. I do not think they will. |
Marc Bourget (209.142.38.81)
Rating: N/A Votes: 0 (Vote!) | | Posted on Tuesday, July 20, 2004 - 6:53 am: | |
Here's a link for purchase of the Nu-metrics that will show the product and some prices http://www.instrumentsales1.com/cgi-local/SoftCart.exe/online-store/scstore/numetr_nite.htm?E+scstore I don't know this business, it was the first one that came up on a Google search with $$ Onward and Upward Marc Bourget |
