Air Suspension Piping Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2004 » July 2004 » Air Suspension Piping « Previous Next »
LarryN-4106 (12.218.106.169)
Posted on Thursday, July 08, 2004 - 3:28 am:
I have to figure this out by morning as I am going to finish the job I started with replacing all four of my front airbags. I would like to replace the copper air lines to these bags with nylon. What I have now is copper with a hodge podge of fittings. I want to start with the airbag lines which are concealed where they connect to the bags.
Any thoughts on using nylon airlines to serve each airbag?
JImmci9 (209.240.205.68)
Posted on Thursday, July 08, 2004 - 3:33 am:
Great idea.....make sure that it's DOT approved tubing... it will have the DOT markings on it, if it is.... then also make sure to secure it so it can't rub or chafe....
TWO DOGS (63.185.72.121)
Posted on Thursday, July 08, 2004 - 3:35 am:
don't know wheather or not it's nylon...but I'd use the plastic line like they use on big trucks...go to a big truck parts house,they also have all the correct fittings
Jim Ashworth (Jimnh) (172.171.77.246)
Posted on Thursday, July 08, 2004 - 1:14 pm:
Yes, fittings are different from copper to plastic. Make sure you use the correct ones and use the ferrules with the shoulders and the little insert that keeps the plastic from collapsing.
One asset that copper has is that the mice can't nibble on it. You might think about replacing the copper with copper if the bus will sit during the winter in an area that has mice.
Jim (who replaced 150' of plastic the mice nibbled)
Bulldogie (69.4.194.92)
Posted on Thursday, July 08, 2004 - 2:20 pm:
Mice and rats are looking for the salt from your hands and fingers that you deposit on the lines as you hook them up. That is the best reason for using copper hehehe
