Transfer switch Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2004 » June 2004 » Transfer switch « Previous Next »
4drifter (4.152.207.252)
Posted on Saturday, June 12, 2004 - 4:44 am:
have a transfer switch has been out of service since 1999, when you put a load on it will run a few minuts and will kick out and back in. have checked the wiring with a meter and they checked ok.any sugestions? thanks
bowlingshoegiverouter (63.185.65.69)
Posted on Saturday, June 12, 2004 - 5:53 am:
you need to explain it a little better,either the switch is bad ,or you are kicking it out because the two ends have a direct short...what kind of bus,where is this switch,whats it hooked up to,need more info
4104 (4.152.207.149)
Posted on Saturday, June 12, 2004 - 12:16 pm:
the switch transfer from shore power to generator is a automatic. it is just like you flip a switch
off and on.does not do this with the battery charger on.
the systems check out ok.
the bus is a 4104 with two ac.
bowlingshoegiverouter (63.185.80.167)
Posted on Saturday, June 12, 2004 - 3:32 pm:
does it do it all the time (bad switch) or just when you run two air conditioners (overloaded)
Jose (63.190.73.50)
Posted on Saturday, June 12, 2004 - 8:57 pm:
You may have rust on the Magnetic contact, A little sand paper will take it off, if You can get to it.
Rust will keep it from latching in solid.
Just a posibility!
Jose, Just a dumb retired mechanic.
