NEED PD4106 turn signal lens Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2011 » September 2011 » NEED PD4106 turn signal lens « Previous Next »
Jim Rink (Fakeguy)
Username: Fakeguy
Post Number: 182
Posted From: 96.11.208.103
Posted on Monday, September 26, 2011 - 2:15 am:
for the the left side below drivers window..mine disintegrated up replacing bulb...see my post in classifieds if you can help. note pic is of good one on right side
thanks
Donnie Daugherty (Dr_detroit)
Username: Dr_detroit
Post Number: 23
Posted From: 98.145.214.90
Posted on Monday, September 26, 2011 - 6:15 am:
Jim, the picture that you posted in the classifieds appear to be an aftermarket light assy that is available at most truck supply places. I don't know what was on the 4106's as original equip but mine has amber round lights about 2" in diameter. I will see if I can attach a pic to show you.
Donnie Daugherty
Enterprise Alabama
PD4106-2772PD4106-2772 Door
Username: Rjlong
Post Number: 1849
Posted From: 71.195.124.20
Posted on Monday, September 26, 2011 - 8:56 am:
Jim -
I agree with Donnie - the TS on the side of your bus is not OEM, it's an aftermarket unit, actually looks like a teardrop clearance light.
The pic Donnie posted is OEM.
Based on that, go shopping at your favorite HD truck parts house or truck stop accessory department and pick up a couple of the new LED models, one for each side. Or do an on-line search for "truck clearance lights" to find a match.
FWIW & HTH. . .
Username: Pd41044039
Post Number: 699
Posted From: 184.0.13.120
Posted on Monday, September 26, 2011 - 2:40 pm:
Be careful about replacing incandescent with LED. I found that if there isn't enough resistance, flashers often don't work right or at all. Kind of like when one of the bulbs is burned out on a car.
I changed out the signal bulbs on our Explorer & had to put the regular bulbs back. They will work fine for running lights.
Tony Gojenola (Akbusnut)
Username: Akbusnut
Post Number: 57
Posted From: 208.98.151.220
Posted on Monday, September 26, 2011 - 6:46 pm:
I believe the item is a Grote # 46543
It googles well - here's one source:
http://www.ryderfleetproducts.com/ryder/af/ryder/core/content/product/srm/key/W38%2046543/ pn/Cab-Marker-Light-Yellow/erm/productDetail.do
tg
Jim Rink (Fakeguy)
Username: Fakeguy
Post Number: 183
Posted on Monday, September 26, 2011 - 10:17 pm:
Hey....thanks everyone...maybe I should do my homework before assuming a part is OEM....I was going to just go to truck stop and get something similar but thought I would try for original part...do not have to worry about that now...will do the easy way
Jim Rink (Fakeguy)
Username: Fakeguy
Post Number: 184
Posted on Tuesday, September 27, 2011 - 3:03 am:
Grote # 46543 ordered 2 thru amazon 10.68 total...will now have 2 new...one on each side. thanks to all for the help
