HondoJoe04 (66.74.52.69)
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, May 24, 2004 - 5:21 am: | |
Hi, My 12kw Kohler gen is powered by the 4 cyl Perkins diesel. The fuel pump just started to leak & I want to run it this holiday wknd. Going to Napa for help tomorrow. But Does anyone have any options... if this crossses over to something or know of a place I can call to order one for overnite delivery?? Thanks, Joe |
TWO DOGS (65.179.192.155)
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, May 24, 2004 - 5:28 am: | |
try THERMO KING.....or someplace that does maintanance on refers |
mel4104 (208.181.100.15)
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, May 24, 2004 - 3:36 pm: | |
if you are near a farm eq. dealer or are near a coast line then try them as a lot of fish boats have them also stationary eg. use them, and a lot of truck shops have parts for them. |
choochoo (206.176.198.238)
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, May 24, 2004 - 4:44 pm: | |
hondo .You may want to try a Cat dealer they now own Perkins or a Massey Fergusen farm dealer they use a lot of Perkins. Ted |
Stephen Fessenden (Sffess) (65.154.177.138)
Rating: N/A Votes: 0 (Vote!) | | Posted on Tuesday, May 25, 2004 - 3:20 am: | |
These people may be able to help you. They are a Perkins dealer and they rebuilt the injection pump on my Perkins powered Kohler 12KW generator. They also have a Tallahassee, FL Shop. Shiver Diesel 1702 Carpenter Rd. Tifton, GA 31794 Tel: 912-382-1595 Fax: 912-382-1573 |
Rating: N/A Votes: 0 (Vote!) | | Posted on Tuesday, May 25, 2004 - 6:05 am: | |
Thanx for the tips!! Got it going okay. Found the fuel line to be loose on the output side! Easy fix, mostly because the unit is on a slide out & I could then easily get at the fuel pump. Checking the lines found they were all a bit loose!! so with a bit of TLC all is well! Thanx again! Joe |
