TWO DOGS (63.185.97.205)
Rating: N/A Votes: 0 (Vote!) | | Posted on Sunday, May 16, 2004 - 5:55 pm: | |
some people won't 'approve' of this....my windshield rubber was cracking on the outer edges....went to the lumber yard...got: 1 tube black 100% silacone,1 roll masking tape,1 plastic 1 1/2" spreader...(5.00 total) put masking tape 1/8" away from rubber,small bead of silacone,worked it smoth with paddel,removed tape,looked at it this morn. BEAUTIFUL |
Robert Wood (Bobwoodsocal) (4.63.41.14)
Rating: N/A Votes: 0 (Vote!) | | Posted on Sunday, May 16, 2004 - 5:58 pm: | |
hey- whatever works! Bob |
Rating: N/A Votes: 0 (Vote!) | | Posted on Sunday, May 16, 2004 - 6:01 pm: | |
just be sure to use the masking tape to keep it NEAT |
Jerry Liebler (165.121.32.89)
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, May 17, 2004 - 12:27 am: | |
When you get to doing a real replacement of the rubber be sure to get all the silicone off & that will be quite a chore. If you don't get it all off you won't get the new seal you've paid for. Regards Jerry 4107 1120 |
TWO DOGS (158.253.192.227)
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, May 17, 2004 - 1:03 am: | |
yeah sure.... |
Buswarrior (Buswarrior) (64.229.208.164)
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, May 17, 2004 - 2:29 am: | |
You go, 2D! I did the same, only used some clear that I had lying around, and did it free hand. Completely functional, with little to no regard for appearances. I'll get new rubbers for the windshields in awhile, and until then, it's a work in progress! And the dirty secret is: new rubbers leak too! So get used to using some goop or other! Don't use it on new install at your peril! happy coaching! buswarrior |
