Post Number: 1505 Registered: 7-2006 Posted From: 70.219.82.221
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, May 23, 2011 - 3:15 am: | |
Anyone know a good source? Thanx, RCB |
Patrick levenson (Zubzub)
Post Number: 285 Registered: 5-2007 Posted From: 174.91.230.210
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, May 23, 2011 - 3:34 am: | |
Take the bits to a local parts jobber they usually send them out and get it done asap. |
Post Number: 1397 Registered: 3-2007 Posted From: 71.55.178.71
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, May 23, 2011 - 2:58 pm: | |
RC, I think that NAPA Still does the cables too. I know they have the cable in stock. Gomer |
Post Number: 2087 Registered: 10-2003 Posted From: 71.58.71.157
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, May 23, 2011 - 9:52 pm: | |
just for info, my 1948 ACF Brill had a speedo cable of two parts; the first section from transmission had a heavier and thicker cable, that then reduced down through a coupler to the common size type. Stewart Warner lists this stuff in their catalog, and look for a speedometer repair shop in the yellow pages near you. Also would be a good time to consider an electronic version, as costs have come down from the past with a greater selection. Several good mfgs. now |
Post Number: 1506 Registered: 7-2006 Posted From: 97.213.4.31
Rating: N/A Votes: 0 (Vote!) | | Posted on Tuesday, May 24, 2011 - 4:04 am: | |
NAPA is one...of my "problems"...tried them a couple of years ago. Local stores have no clue...plus they have now changed ownership. Worse. I ordered cable to DYI, but cut it too long (I guess)..would not function without binding...cut a bit off, re-brazed, now "won't function"....too short?; don't know, but I have now gone several thousand miles without it. For the "next owner", if any, would like to have the thing working properly. Tell me more about "electronic version"///In this part of the third world there are no (at least known to me) speedo shops; ergo the original question. Thanx RCB |
Brice Abell (Babell2)
Registered Member Username: Babell2
Post Number: 18 Registered: 12-2010 Posted From: 72.145.156.15
Rating: N/A Votes: 0 (Vote!) | | Posted on Tuesday, May 24, 2011 - 4:37 am: | |
The thing you have to keep in mind is that Napa is a franchise. Nane not ownership. You get whwt you pay for. |
Post Number: 1528 Registered: 10-2006 Posted From: 75.58.180.30
Rating: N/A Votes: 0 (Vote!) | | Posted on Tuesday, May 24, 2011 - 10:45 am: | |
The problem with NAPA is they usually only stock or supply what is in the NAPA supply chain. Same for Auto Zone and the rest of the chain stors.. An unbranded shop will have dozens of sources NAPA doesn't have , and is used to trolling the suppliers for just what a customer needs. This is a daisy chain , folks with problems go to the private shop with problems , so the folks there have far more experience at problem solving. Amazing what a smart experienced counter guy can come up with! OR who he will send you to to solve your problem. FF |
Post Number: 637 Registered: 2-2001 Posted From: 70.63.209.208
Rating: N/A Votes: 0 (Vote!) | | Posted on Tuesday, May 24, 2011 - 12:49 pm: | |
Why not convert to an electronic speedo? They run off 4 bolt heads on the front driver's side brake drum. If the drum does not already have them, it's a piece of cake to drill & tap. Ours is just very accurate compared to GPS. |
Post Number: 1508 Registered: 7-2006 Posted From: 97.226.144.253
Rating: N/A Votes: 0 (Vote!) | | Posted on Tuesday, May 24, 2011 - 3:51 pm: | |
Jim...tell me more! Don't find much definitive on the web. Very unclear as to parts needed,etc. Prices seem to range widely; most probably on "what is included". .....And I don't care to go back to NAPA, at least here in Las Cruces. Thanx RCB |
Post Number: 2088 Registered: 10-2003 Posted From: 71.58.71.157
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, May 25, 2011 - 1:04 am: | |
here's a good company to peruse: http://www.autometer.com/default.aspx also check their faq section on speedometers |
Post Number: 2089 Registered: 10-2003 Posted From: 71.58.71.157
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, May 25, 2011 - 1:10 am: | |
also this one: http://www.texasindustrialelectric.com/speedo.asp |
Post Number: 1509 Registered: 7-2006 Posted From: 97.226.144.253
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, May 25, 2011 - 2:54 am: | |
Hey, JWR...methinks you might have come up with something!!!...thanx! RCB |
Post Number: 1399 Registered: 3-2007 Posted From: 71.55.178.71
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, May 25, 2011 - 2:55 am: | |
Thanks Chessie for the link. I needed that for my restoration projects around here Gomer |
