Defroster Motors. Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2011 » March 2011 » Defroster Motors. « Previous Next »
Bob Glines (Robertglines1)
Username: Robertglines1
Post Number: 19
Posted From: 75.207.166.201
Posted on Wednesday, February 23, 2011 - 1:10 am:
Leaving for sun in the morning. Turned on defroster motors nothing from either: Bypassed switch with 24 volt to motors (indivaualy) nothing. Added frame ground seperate: still nothing. 3spd motors 12 volt low 19.7 volt med and 24 volt high. confused why they won't start wired direct???? Bob
Post Number: 1246
Posted From: 71.55.4.4
Posted on Wednesday, February 23, 2011 - 1:54 am:
Bob, They maybe just stuck from sitting and if you have the cover off see if you can't spin them and if you can't you can take them apart and clean and oil each motor. I have done that on several units and they worked good after that. If you need to replace the bearings I got mine from Miller bearings here,and they got real quiet after that. Brushes can be replaced also.
Gomer
Post Number: 20
Posted on Wednesday, February 23, 2011 - 1:59 am:
Maybe bump with hammer if that don't work get a bigger one. Hope not to need them in Fla.
Post Number: 1247
Posted on Wednesday, February 23, 2011 - 2:20 am:
Bob I live in Ocala, Where are you? Check provile and all my info is there
Gomer
Post Number: 21
Posted on Wednesday, February 23, 2011 - 2:24 am:
Will be at Wilderness on 40 east prob thursday. Hi Yo Silver is there also. Will call. be there till april. Bob
Post Number: 1248
Posted on Wednesday, February 23, 2011 - 2:27 am:
I am on 40 West about 5 miles from I-75. do call and we will get together and have some coffee or SWEET TEA LOl
Gomer
Post Number: 22
Posted From: 75.224.87.150
Posted on Tuesday, March 01, 2011 - 2:38 am:
Update: Defective ground. would test good but when load applied it failed. Note to self ;don't trust your test just establish a new one when in doubt. Bob
Russell Beam (Rcbeam)
Username: Rcbeam
Post Number: 54
Posted From: 74.131.51.40
Posted on Wednesday, March 02, 2011 - 2:42 am:
Speaking of defroster motors, I needed brushes for the two in my MC8. Went all over town and no one had brushes for them. Napa, Carquest, the DD shop, electric and industrial motor shop,etc. Figured it would be easy. Took them to a guy that rebuilts alternators and stuff and he is going to order brushes and check out the bearings and all for me. So much for being an easy fix.
Username: Pd41044039
Post Number: 601
Posted From: 184.0.13.120
Posted on Wednesday, March 02, 2011 - 4:39 pm:
I just got brushes for my motors from a power tool repair shop. They were 1/4" square with captive spring just like a drill or saw. Bearings from same place $1. each.
