6v92 engine parts Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2011 » February 2011 » 6v92 engine parts « Previous Next »
scott kneifel (Kneifels)
Username: Kneifels
Post Number: 1
Posted From: 67.236.192.87
Posted on Thursday, February 10, 2011 - 1:14 am:
hello all,i am getting ready to rebuild a new engine.im told that the cams for the coach with the gear driven alt is different from the trucks.i bought a basket case engine that looks awesome but a detroit parts guy says dont use them.not sure if he just wants the sale.anyone got knowledge on cylinder kits,cams and turbos that work well together on a mechanical engine?thanks.scott
Username: Luvrbus
Post Number: 1031
Posted From: 74.33.43.204
Posted on Thursday, February 10, 2011 - 2:18 am:
They are different so is the cam gear and drive, you will also need the spacer check with Don Fairchild 1-661-391-4521 he can also give you all the info you ask for and he sales the kits what are you installing this engine in not a MCI I hope
good luck
(Message edited by luvrbus on February 09, 2011)
Steven Foster (57_gmc)
Username: 57_gmc
Post Number: 30
Posted From: 72.156.216.251
Posted on Thursday, February 10, 2011 - 1:15 pm:
Hi Scott: I just got my 6-71 back together and it running great. I know there is a lot of help here on the board as Im still new to my bus and got a lot of info reading here. I got all my parts that you might check out as the price was good and the kits were good stuff. www.heavydutykits.com they were very nice and helpful on my rebuild. Have fun with your project.
Thanks
Steve
Username: Kneifels
Post Number: 2
Posted From: 69.95.122.235
Posted on Thursday, February 10, 2011 - 2:25 pm:
6v92 in a mci9.from what i see it doesnt look too bad to do this.the rebuild will be time consuming.thank you
Username: Luvrbus
Post Number: 1034
Posted From: 70.103.89.102
Posted on Saturday, February 12, 2011 - 1:46 am:
You will have your self a ball changing all the parts from a truck engine to a MCI engine,truly I hope you have a 6v92 from a MCI if not those parts are going to be a little pricey
good luck
Ralph Peters (Ralph7)
Username: Ralph7
Post Number: 184
Posted From: 75.223.94.220
Posted on Saturday, February 12, 2011 - 6:22 pm:
IF you do not have the MCI gear drives for the rear of the engine, the truck engine will work. But you will be short one drive, you can change the truck alt. drive on the blower end to drive the PS pump, also pump must turn oppsite direction, and mount the compressor on the(bus right side) drive. Then make a alt. mount, an drive it off the crank if you do not need the big bus alt..
Do you have the bus cradle and bus rear(upside down V back of bus) engine mount? Cause there is a difference in the mount, bus/truck, makeing a sling to mount that end?????????
Username: Luvrbus
Post Number: 1035
Posted on Sunday, February 13, 2011 - 5:39 am:
Different bell housing and end plate on a truck engine than a MCI engine if you have the old MCI engine change the cam,bell housing end plate and the drives be done with it then everything will work
good luck
Username: Kneifels
Post Number: 3
Posted on Sunday, February 13, 2011 - 6:14 pm:
yes i have the engine from the bus.basically building a short block and swapping parts to new short block.thank you all for your input.
Bill Gerrie (Bill_gerrie)
Username: Bill_gerrie
Post Number: 428
Posted From: 216.198.139.38
Posted on Sunday, February 13, 2011 - 6:31 pm:
Scott
I hope you have the engine service manual to guide you. A lot of things to watch for as no head gasket. Different from a car engine. Call if you have any questions as I have the books and have rebuilt several DD's.
Bill
