jmaxwell (66.81.213.72)
Rating: N/A Votes: 0 (Vote!) | | Posted on Sunday, October 26, 2003 - 5:35 pm: | |
The simple and quick comparison is the percentage change, without doing all the math or getting your hands on a chart. 492 and 505 will yld. 3.3 and 6% change respectively. Referencing your 476 at 60mph, given the same engine rpm at 1:1 out of the tranny will yield 58 and 56.5mph and require 60 and 108 more engine rpm to maintain 60mph, respectively. Not much change and probably barely noticeable, if at all. Final drive gear ratio is the answer if u want to lower top end speed or gain hill power. Agreed, that's not quite as easy as changing tires! |
