Bennett Shifter. Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2011 » January 2011 » Bennett Shifter. « Previous Next »
Iver (Mciv)
Username: Mciv
Post Number: 38
Posted From: 70.69.131.252
Posted on Friday, January 14, 2011 - 9:56 am:
Does anyone the "simple version" of connecting a 12v Stone Bennett shifter in a 24v system?
Thanks to Clifford I have enough of a manual to get all the mechanical connections hooked up and some of the electrical.
I am making my own control with a toggle switch and a series of led indicator lights as I have seen others do.
I understand when the shift actuator moves up or down, it grounds the various led's to show what gear has been selected. I was going to run an 8 wire 20ga signal cable for the led lights.
I would like to control the shifter through the ignition so it works when the ignition is on.
But the ignition is 24v.
I also wanted to have the ignition operate only when the shifter is in neutral.
I can run 12v for the shifter solenoid right from the control. If so, what size of wire?(@50ft).
Or I can use relays in the engine compartment and take 12v from there. Then what size of wire for the 50ft.
Any help would be appreciated.
Thanks, Iver.
Bill Gerrie (Bill_gerrie)
Username: Bill_gerrie
Post Number: 409
Posted From: 216.198.139.38
Posted on Friday, January 14, 2011 - 4:14 pm:
Iver
Go to my profile and call me. Give your phone number and I will call you. There is too much to explain here. Especially the neutral shutdown.
Bill
Iver (Mciv)
Username: Mciv
Post Number: 39
Posted on Saturday, January 15, 2011 - 5:52 am:
Hi Bill,
Thanks for the kind offer of help. I will try to get some time shortly and will certainly give you a call.
What would be very helpful to me, (sometimes slow to understand), is a rudimentary sketch of the wires and their connections.
I do have some instructions and drawings, but nothing showing the details I need especially when dealing with the 12v and 24v systems.
Thanks, Iver.
Abbotsford, B.C.
