two dogs (67.30.23.123)
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, August 18, 2003 - 5:52 pm: | |
After days & days of hammering & drilling & plasma torch...finally found a good way to get those corroded screws out..this is mainly for the archives,since there is probably nobody doing it right now high speed air cutter,some people call them muffler cut off tools..on the inside of the bus,the alum. frame is 1" & then 1/2 rubber gasket.take the cutter,(harbor frieght#47077) and go right into the rubber gasket,down to the s/s screw & cut through it...weeeeeeeee |
