Post Number: 1370 Registered: 10-2006 Posted From: 66.82.9.25
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, November 24, 2010 - 6:47 pm: | |
In putting together the front we just realized the S cam bushing on one side is shot. Would like to find a pair , and zero time the entire front brake system. Any suggestions for a source ? The Flex VL 100 is a 1956 if that makes a difference. Some imbecile removed the tag from the axle , sometime in the coaches past , so just a positive ID would help. It is always easier to purchase than simply machine from raw stock , so here's hoping. Thanks,, FF |
larry currier (Larryc)
Post Number: 339 Registered: 2-2007 Posted From: 207.200.116.13
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, November 24, 2010 - 7:20 pm: | |
Hi Fred, Couple of ways I would go about it. If you can knock one of the old ones out, any large commercial brake shop should have them, maybe your NAPA. The S cam and round tubing are going to be relatively common. So the bushing should also be common. You can also mike the ID and OD and go to the brake supply and start looking. This may be easiest. If you have room for a wider bushing, put the wide bushing in because it will last longer. Make a wire probe with a small hook on the end and check behind the worn bushing to see if there is a space that allows pounding the new one in while leaving the old one to be pushed farther into the tubing. You can also use the wire to get a real close measurement of the bushing width while you are at it to check for space to allow 2 bushings in the tubing. Or, take the S cam to the brake shop and see what bushing fits the shaft, use a tape measure to get the OD and knock the new bushing in right on top of the old one. |
Post Number: 974 Registered: 8-2006 Posted From: 74.33.54.135
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, November 24, 2010 - 7:44 pm: | |
They use the same s cam and bushing as a 01 Eagle call Jefferson in OKC good luck (Message edited by luvrbus on November 24, 2010) |
Donald P H (Eagle19952)
Registered Member Username: Eagle19952
Post Number: 46 Registered: 11-2007 Posted From: 98.238.118.43
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, November 25, 2010 - 7:20 am: | |
http://www.ryderfleetproducts.com/ryder/af/ryder/core/content/product/srm/key/439%20E3993B /pn/Camshaft-Repair-Kit-QQplus/erm/productDetail.do Call these folks....Tel: 1-800-759-6479 or 770-277-9629 |
tony denny (Papatony)
Registered Member Username: Papatony
Post Number: 12 Registered: 10-2010 Posted From: 74.206.82.239
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, November 25, 2010 - 7:54 am: | |
Check any big truck supplier Truck Pro is a great source.. |
Post Number: 1372 Registered: 10-2006 Posted From: 66.82.9.20
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, November 25, 2010 - 1:46 pm: | |
Euclid Camshaft Repair Kit QQplus E3993B You think Euclid made the brakes in 1956? FF |
Post Number: 47 Registered: 11-2007 Posted From: 98.238.118.43
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, November 25, 2010 - 6:24 pm: | |
Maybe...Maybe not....probably,(Euclid/Terex has been around for almost as long as DD), BUT Euclid makes repair kits for most everything imaginable. |
