Crown Guys Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2003 » July 2003 » Crown Guys « Previous Next »
dougthebonifiedbusnut (136.217.0.198)
Posted on Wednesday, July 23, 2003 - 9:15 am:
Anybody got a hydraulic clutch in their coach?
Posted on Wednesday, July 23, 2003 - 4:39 pm:
I used to have one in my last bus, and it was ok but I'll tell you what a pain it caused when the slave cylinder failed one day when I was in the mountains on dirt backroads. NEVER want one of those again.
For my Crown, I took out the factory 17" single plate disc, redrilled my flywheel and mounted a Lipe 2-disc "ez push" ceramic-puck clutch. The darned thing is now easier to push than my honda accura!!! If that appeals to you, you can get one from Dennis at Valley Truck in Fresno, Ca.
It's a bit of work but much stronger than the single plate clutch and well worth it.
If you want to put in a hydraulic clutch for other reasons, like ya just can't deal with the linkage of a mechanical clutch, etc, then hydraulic will work, just go to a truck junkyard and grab one. You could also stick a "Hydrovac" assist unit on the system if you could find vacuum to power it...
Cheers
Gary
Posted on Saturday, July 26, 2003 - 8:19 pm:
I think my '74 10-wheeler has a rod thing that actually connects the pedal to the clutch but I am not sure as it was my brother who removed the actual clutch pedal to grind it down soosss the pedal was lower to the floor. CROWNS FOREVER!!
Also maybe it was you who mentioned that you knew an individual up in the NW who had installed a Big Cam 400 Cummins into a Crown Super Coach and if soooss, how did he do the intercooler? I would like to upgrade my 250 Cummins into a 400. Thanks.
doughtebonifiedbusnut (136.217.0.198)
Posted on Sunday, July 27, 2003 - 1:49 pm:
Hey Henry,
As far as i know he left it stock.He also put a easy push cluth in. there is a company in Philly that is very knowledgeable about making h.p. with 855 cummins engines will send you the email address Oh ya the same guy put a set of jakes on the same engine HE has a very nice crown.
