bster (198.81.26.104)
Rating: N/A Votes: 0 (Vote!) | | Posted on Tuesday, July 08, 2003 - 9:15 pm: | |
the ol 4104 steers with one finger now (rts box) new style vickers pump i would like a little resistance on the steering wheel can i squash the spring down on the pump for less pressure im not shure i like it its to easy its like a cadilac and not a bus help? p.s. thanks for the help sorting the pump out it was turning the wrong way (not the bus) |
Geoff (Geoff) (66.238.120.135)
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, July 09, 2003 - 12:00 am: | |
My RTS steers with one finger (forefinger, not middle). Your 4104 being a lot lighter it should really be easy to turn. I don't think you can adjust the pump-- the spring in the pump would be a pressure relief spring, not an output pressure spring. Also, you should be using 10w-30 wt oil, or even straight 30 wt oil, not Dexron. |
Frank Allen (205.188.208.39)
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, July 09, 2003 - 10:02 am: | |
I have not seen where 10w30 oil is recomended for power steering, would it not depend on what kind of steering is involved? ive seen straight 10wt and dextron. Frank Allen 4106 |
Geoff (Geoff) (66.238.122.223)
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, July 09, 2003 - 7:05 pm: | |
It is recommended in the GMC RTS manual and there is also a decal on the power steering resevoir on all RTS that states use 10w-30 or 10w-40. The local steering gear shop says 30wt is okay also. UPDATE: I just looked in my manual and it states in bold letters "DO NOT TO USE DEXRON OILS IN POWER STEERING SYSTEM" (section 9-13, RTS '04 Manual) |
Frank Allen (152.163.252.163)
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, July 11, 2003 - 10:22 am: | |
wonder if the RTS power steering pumps are different from the 4106 pumps? not trying to be smart just trying to learn something. mine has dextron and im wondering if i wouldnt be better off with the oil, also how would i get it out of the system?? it has a sheppard unit on it. Frank Allen 4106 |
Luke Bonagura (Lukeatuscoach) (12.90.4.6)
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, July 11, 2003 - 9:27 pm: | |
Hi Frank: I assume, when your 4106 was converted to Sheppard steering, that the proper pump was also installed??? The fact of the matter is that your Sheppard system uses motor oil and not ATF. To get ATF out will require some effort, but get it out and replace it with motor oil. I Hope this HELPS!!! and have a GREAT!!! weekend. LUKE at US COACH |
