FAST FRED (67.75.110.22)
Rating: N/A Votes: 0 (Vote!) | | Posted on Sunday, June 22, 2003 - 2:17 pm: | |
Folks that may suffer from bad old fuel contamination may wish to visit this site. http://www.powerservice.com/ In the past I have done very well with Biobor , but this seems to be a system, which perhaps does work. MFG Claims it gets the water too. No doubt emptying ,removing and a steam cleaning the fuel tanks would work better , but this could be a solution. I have also had very good results from using a vacume style oil change pump (Tempo or similar)with a thin plastic suction tube worked into the far corners of the tank . While a simple drain plug works wonders , not every tanks can be operated. FAST FRED |
jmaxwell (66.42.92.16)
Rating: N/A Votes: 0 (Vote!) | | Posted on Sunday, June 22, 2003 - 4:57 pm: | |
The 175 gal. tank in my Neoplan has two sediment wells of approx 1 gallon capacity each, with plugs; good design planning, I think. |
