Does anyone know the part # for the a... Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2010 » May 2010 » Does anyone know the part # for the accessory drive pulley thingy that bolts to « Previous Next »
Patrick levenson (Zubzub)
Username: Zubzub
Post Number: 216
Posted From: 70.52.29.11
Posted on Tuesday, May 18, 2010 - 2:11 am:
the back of a 6-71? Do all the other -71 share this part? How about the -92?
Thanks for any and all info. Patrick.
Username: Joemc7ab
Post Number: 418
Posted From: 66.38.159.33
Posted on Tuesday, May 18, 2010 - 3:40 am:
Patrick
I believe you are referring to the flywheel housing, there are for the most part two versions sae #1 and #2 and for our old bus applications you will find the #1 the most common.
Joe.
Username: Joemc7ab
Post Number: 419
Posted on Tuesday, May 18, 2010 - 3:46 am:
not sure if the flywheel housing is interchangeable between 71 and 92 versions. If you need to know, I will have to take a tape measure and check.
Username: Joemc7ab
Post Number: 420
Posted on Tuesday, May 18, 2010 - 3:50 am:
should have read the fine print in the heading.
Username: Joemc7ab
Post Number: 421
Posted on Tuesday, May 18, 2010 - 4:10 am:
Still donot have #, but 71 and 92 are not interchangable,71 has 5bolts and92 has 6 bolts for mounting. Flywheel housings are quite different also.
Joe.
don goldsmith (Bottomacher)
Username: Bottomacher
Post Number: 273
Posted From: 68.223.70.93
Posted on Tuesday, May 18, 2010 - 2:14 pm:
I may have one. Email me off the board if interested and I'll try to get a photo.
Username: Pd41044039
Post Number: 477
Posted From: 184.0.3.170
Posted on Tuesday, May 18, 2010 - 4:49 pm:
Patrick, aren't you talking about the accessory drive that bolts onto the flywheel housing and has a pulley to drive your alternator?
Not the flywheel housing itself.
Username: Joemc7ab
Post Number: 422
Posted on Tuesday, May 18, 2010 - 7:49 pm:
Jim
That is correct, but sometimes we answer without really knowing what the question really asked for.
Joe.
Username: Chessie4905
Post Number: 1898
Posted From: 71.58.71.157
Posted on Tuesday, May 18, 2010 - 10:57 pm:
Check with Leid Diesel in Newville, Pa. I'm positive they would have one. 717-776-7725
Username: Zubzub
Post Number: 219
Posted From: 174.93.212.231
Posted on Tuesday, May 18, 2010 - 11:23 pm:
I'll try to clarify but as I don't have any part #s/names so it is a little hard to be clear.
I am looking for the accessory drive housing and bits that bolt (using 5 bolts) onto the back of a 6-71. It bolts on gear train cover (above the flywheel cover) where a gear driven generator/alternator would usually be. There seem to be a few different ones out ther. A part # would allow me to order one online .
Post Number: 1900
Posted on Wednesday, May 19, 2010 - 1:38 am:
call Leid... they supplied ours; just tell them what you want. They were also used on 8-71's and 6-71's in over the road trucks, since they used belt drive alternators.
Donnie Daugherty (Dr_detroit)
Username: Dr_detroit
Post Number: 11
Posted From: 74.87.222.155
Posted on Wednesday, May 19, 2010 - 6:32 am:
There are two types of accessory drives, one with a bearing assy in the cover and the other with only a seal in the cover since it flanges directly to the camshaft gear without a coupling like the other. I will try to attach photos of both types complete with part numbers.
The pics were too big to attach, I will send them to your e-mail that is listed in your profile. You might want to check your spam folder for mail from dr_detroit_98@yahoo.com
Donnie Daugherty
Enterprise Alabama
PD4106-2772
Username: Zubzub
Post Number: 220
Posted on Wednesday, May 19, 2010 - 11:01 am:
Thanks Donnie.
