Jim Huskins (Lostranger)
Registered Member Username: Lostranger
Post Number: 11 Registered: 8-2007 Posted From: 68.238.120.80
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, May 17, 2010 - 2:26 pm: | |
Anyone have a working turbo you'd like to sell? Will any other turbo fit this engine? I'm considering buying a bus that's several hundred miles from home, and it has a hole in the puffer. I have one on a 6v92 (left hand rotation), but I guess that won't work, huh? |
Ralph Peters (Ralph7)
Post Number: 121 Registered: 3-2004 Posted From: 75.224.122.200
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, May 17, 2010 - 3:17 pm: | |
Jim I tryed your Phone## but it did not work. So call 717-776-7725 Lied Diesel they will know and should some in stock, may have used also. They are in Pa. and ship, daily. |
Patrick levenson (Zubzub)
Post Number: 215 Registered: 5-2007 Posted From: 174.91.217.34
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, May 17, 2010 - 3:26 pm: | |
Pretty sure the turbo doesn't care which way the engine turns. It's more the size, about it fitting on the exhaust properly, having an output where it's supposed to be and other appropriate fittings.... |
Post Number: 12 Registered: 8-2007 Posted From: 68.238.120.80
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, May 17, 2010 - 4:51 pm: | |
Thanks Ralph7 for the contact. I'll try to get my number updated soon. Timothy at Lied Diesel was most helpful. Says the 6v92 turbo will bolt up and work if both engines are same vintage (early or late). I'm checking that further today. |
Post Number: 888 Registered: 8-2006 Posted From: 74.32.87.183
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, May 17, 2010 - 5:55 pm: | |
Get the model number for me I have 3 or 4 here in AZ there are 12 or more for a 8v92 if a high horse hp engine the TV 8511 is a good turbo for torque at the high end but smokes a little on take off. My advice is check the A/R on both sides the hot side A/R is located inside the hot housing housing, the turbo is matched to the injector,cams and liners so be careful installing any other turbo on the engine. The model and serial number is located between the 2 housings on the center piece |
Post Number: 13 Registered: 8-2007 Posted From: 68.238.120.80
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, May 17, 2010 - 6:02 pm: | |
I should have been more clear that I'm only interested in getting this bus home. It's about 600 miles from here. As part of the conversion, I'm going to repower with a 50 series coupled to a 13 speed Road Ranger. The 8v92 runs but has a hole in the turbo, and I can't imagine trying to limp it home in that condition. Thanks for all the response. Jim |
clint hunter (Truthhunter)
Post Number: 622 Registered: 1-2009 Posted From: 24.129.238.13
Rating: N/A Votes: 0 (Vote!) | | Posted on Tuesday, May 18, 2010 - 3:21 am: | |
...but did any other engine damage occurs when the hole appeared in the turbo that will make itself apparent a few miles down the road ? might be the same price to have it towed or low bedded home as a haul back, if time isn't short. Phone around for a quote, the local bus shops will know who is equipped. |
Post Number: 14 Registered: 8-2007 Posted From: 68.238.120.80
Rating: N/A Votes: 0 (Vote!) | | Posted on Tuesday, May 18, 2010 - 8:54 am: | |
I've learned that my 6v92 turbo is the older style and will not bolt to this 8v92. Does anyone have contact info for a truck wrecking yard near Fancy Gap, VA? I hear they may have the turbo I need, but I don't even know the name of the place. I've already investigated all the transport options, and none are cost effective. I'm confident I can driver 'er home if I can get the turbo swapped. |
Post Number: 217 Registered: 5-2007 Posted From: 70.52.29.11
Rating: N/A Votes: 0 (Vote!) | | Posted on Tuesday, May 18, 2010 - 1:34 pm: | |
Matlock's Auto Recycling 3132 Fancy Gap Hwy Hillsville, VA 24343 866-895-1246 Try them...if it's not them they should be able to tell you who is. |
Post Number: 1184 Registered: 10-2006 Posted From: 76.248.150.30
Rating: N/A Votes: 0 (Vote!) | | Posted on Tuesday, May 18, 2010 - 6:31 pm: | |
"50 series coupled to a 13 speed Road Ranger" Most coaches do not weigh enough , even with a heavy trailer to need to row thru 13 speeds. 5 or 6 will do as well. The goal if light is 1350-1400rpm at 60 -65 Or if really heavy 1500rpm or so at 60-65 This is supposed to give the fuel mileage you would expect from a more modern 4 stroke. The latest thinking in 80,000lb trucks is a 2.64 rear so no power loosing OD is needed. Top gear is straight thru , most efficient. FF |
Dale Waller (Happycampersrus)
Registered Member Username: Happycampersrus
Post Number: 381 Registered: 7-2005 Posted From: 166.231.114.97
Rating: N/A Votes: 0 (Vote!) | | Posted on Tuesday, May 18, 2010 - 9:07 pm: | |
I live here and it's not Matlocks. LOL Strickland's Auto & Truck (276) 755-4429 1564 Old Pipers Gap Rd Cana, VA 24317 http://www.merchantcircle.com/blogs/Stricklands.Auto.And.Truck.Service.276-755-4429/2009/8 /Stricklands-Truck-and-Auto-Repairs-Salvage-/366667 HTH, Dale |
