4106 shocks Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2010 » April 2010 » 4106 shocks « Previous Next »
thomas flocks (Taflocks)
Username: Taflocks
Post Number: 210
Posted From: 74.76.246.165
Posted on Wednesday, April 07, 2010 - 12:26 am:
slight problem. the fine folks at gabriel told me the shocks for the 4106 would be model #85711. nope i just went out and slid under the bus and got the shock of my life. the shocks i need have holes on the top and bottom the ones i got have a spindle at the top. any idea what would be the proper part number? thanks
Bob MacIsaac (Wildbob24)
Username: Wildbob24
Post Number: 94
Posted From: 98.92.170.105
Posted on Wednesday, April 07, 2010 - 1:14 am:
Thomas,
I don't have the Gabriel #s but can give you the OEM #s: Front: 5527272; Rear: 5527271. perhaps they can cross-reference them.
Another way to figure our what you have would be to look a the existing shocks. There should be a part # stamped on them.
Bob
Username: Taflocks
Post Number: 211
Posted on Wednesday, April 07, 2010 - 1:31 am:
SHOCKS I HAVE may be original? they look a little rusty.i had those numbers which we crossed to a monroe 74400 which the gabriel people crossed to a #85711. i will call in the morning to see what we can find out. thanks for your help!
Username: Taflocks
Post Number: 215
Posted on Wednesday, April 07, 2010 - 2:33 am:
i just found the part number it is gabriel # 85700
Laryn Christley (Barn_owl)
Username: Barn_owl
Post Number: 654
Posted From: 72.66.166.244
Posted on Wednesday, April 07, 2010 - 6:48 am:
A little search turned this up:
http://www.busnut.com/bbs/messages/233/28574.html
Username: Taflocks
Post Number: 218
Posted on Wednesday, April 07, 2010 - 1:31 pm:
i ask that anyone that needs shocks please buy them from gaberial these wonderful people are sending 4 more shocks at no cost by fedex!!!
Post Number: 868
Posted From: 71.53.153.91
Posted on Wednesday, April 07, 2010 - 2:12 pm:
COOL
gomer
Wec4104 (Wec4104)
Username: Wec4104
Post Number: 75
Posted From: 71.59.85.113
Posted on Wednesday, April 07, 2010 - 2:57 pm:
Just curious, are you doing the front shocks, the rear shocks, or all. It caught my eye when you mentioned they are sending you four shocks. On my 4104, there are four shocks at the rear axel. I would have guessed the 4106 was the same.
Post Number: 869
Posted on Wednesday, April 07, 2010 - 3:52 pm:
WEW4104, What year is your o4? mine is a 57 and it has only one per wheel. Wondering if it may have been added on as per PO?
Gomer
Username: Taflocks
Post Number: 220
Posted on Wednesday, April 07, 2010 - 4:52 pm:
1 each axle at least i hope....
Wec4104 (Wec4104)
Username: Wec4104
Post Number: 76
Posted on Wednesday, April 07, 2010 - 6:08 pm:
My 4104 is a 1959, and I don't think it was owner modified in that regard, so I checked my GM COACH MAINTENANCE MANUAL. Section 14, page 221 has a drawing of the rear axle set up just the way mine is. Two air bags and two shocks, at EACH of the rear wheels.
I'm not saying the '06s are necessarily set up the same way. But since an 8V71 isn't any lighter than a 6-71, it would surprise me a bit to find out that GM changed to less shocks.
EDIT: By the way, one of the rear shocks is mounted in front of the axel (but behind the front air bag). The other is behind the axel (but in front of the rear air bag). Wondering which is not present on Gomer's 57.
(Message edited by WEC4104 on April 07, 2010)
Post Number: 870
Posted on Wednesday, April 07, 2010 - 9:11 pm:
Wec: Mine has only one shock on the rear. It is mounted behind the axle and the top is about centered on the beam. It wasn't hard to get off when I replace the air bags and plates.
gomer
Username: Chessie4905
Post Number: 1877
Posted From: 71.58.71.157
Posted on Wednesday, April 07, 2010 - 9:49 pm:
mine had 4 at the rear-1958
Username: Gusc
Post Number: 1152
Posted From: 173.202.40.19
Posted on Thursday, April 08, 2010 - 2:10 am:
My parts book dated 1960 shows the 4104 with two shocks on each axle.
Wec4104 (Wec4104)
Username: Wec4104
Post Number: 77
Ahhh, so how about you 4106 owners, how many shocks you got on the rear axel?
Post Number: 872
Posted on Thursday, April 08, 2010 - 2:19 am:
Ok Guys; I'll crawl under mine and see if ther is another place to set another shock in. I don't think so but I will check and let ya'll know. If I am wrong, I will be the first to admit I was WRONG and take my forty lashes with a wet noodle. GHEZE you guys know how to hurt a guy!! LLOLLLOOOOOLLLLO \
Gomer
Wec4104 (Wec4104)
Username: Wec4104
Post Number: 78
Posted on Monday, April 12, 2010 - 12:08 am:
Nobody gonna step up and say how many rear shocks they have on a 4106?
Username: Pvcces
Post Number: 1324
Posted From: 65.74.68.207
Posted on Monday, April 12, 2010 - 2:41 am:
four
Suncatcher
Ketchikan, Alaska
Username: Jack_fids
Post Number: 26
Posted From: 166.183.161.109
Posted on Monday, April 12, 2010 - 3:00 am:
Oh OK...if nobody tells any of the rest of the 4106 owners that it was ME that broke the code of silence.
....I checked "Da Book" and it shows part numbers for a left & a right PAIR of shocks in the REAR SUSPENSION nomenclature section (14-25) ... Parts #5527271 and #5527272.
The 5527272 is the same number used for the FRONT shocks ONLY, there is a warning about the differences between the rears & the fronts.
Looking at the only diagram of the rear axle available in either of the 2 books, there is only a single shock mount on each side of the rear axle.
This sure would have been easier if I had mine aired-up so I could peek under it....my best recollection is that there are only 2 shock total on the rear, I remember knowing that I only needed to buy 4 when I replaced the fronts, & then went the cheap way.
