Post Number: 1789 Registered: 10-2003 Posted From: 71.58.71.157
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, December 04, 2009 - 3:46 am: | |
My 4905 has a cruise control unit on it. The cruise controller has an external wheel about 1 1/2 inch in diameter on the side of it. The cable wraps around this and the other end of the cable assembly( about 3 1/2 feet long ) attaches to the air throttle lever on the governor cover. The idea is that the wheel rotates and the cable then pulls the throttle open. It doesn't work. Anybody have any idea as to what brand it might be, so I could find some info to fix it. Looks to have been on the coach for a few years. |
thomas flocks (Taflocks)
Registered Member Username: Taflocks
Post Number: 107 Registered: 9-2009 Posted From: 24.226.54.174
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, December 04, 2009 - 11:43 am: | |
king controls? what do you have in the cockpit? |
Bill Gerrie (Bill_gerrie)
Post Number: 316 Registered: 3-2006 Posted From: 216.198.139.38
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, December 04, 2009 - 4:21 pm: | |
John Many years ago I had a similar type on a van. I don't see how the motor could pull on the air throttle lever as it is very hard to pull. The motor probably burned out from the strain. On my coach I used an ordinary cruise control and had it pull on the foot pedal as it is easy to pull. It worked great and then I switched to an electronic engine and cruise control is part of the electronics. Contact Pete Papas in FL as he sells a good cruise set up. Bill |
Post Number: 1790 Registered: 10-2003 Posted From: 71.58.71.157
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, December 04, 2009 - 10:59 pm: | |
King's unit has a cable coming out of the large control box. This doesn't look like a box; more shaped like the vacuum type that GM used on cars in the seventies and eighties, but twice the size with the rotating wheel on the side. Not vacuum though. |
Post Number: 811 Registered: 8-2006 Posted From: 74.33.54.207
Rating: N/A Votes: 0 (Vote!) | | Posted on Saturday, December 05, 2009 - 12:29 am: | |
John, I believe that is a Bendix saw a lot of GM's with those good luck |
