A clean toad ? Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2009 » November 2009 » A clean toad ? « Previous Next »
Username: Bigrigger
Post Number: 282
Posted From: 24.183.21.246
Posted on Wednesday, November 04, 2009 - 4:10 am:
I am sure this has been discussed before, but I wonder if anyone has any good ideas for a shield or something (I am thinking plywood) that would mount in front of our Focus (maybe on the towbar) and keep some of the DD flotsam and jetson (read oil smoke) off the front of the car.
Bill Gerrie (Bill_gerrie)
Username: Bill_gerrie
Post Number: 303
Posted From: 216.198.139.38
Posted on Wednesday, November 04, 2009 - 4:53 am:
John
Do you use a container with the air box drains in it? It saves a lot of mess on the toad and the rear of the bus.
Bill
Roger Baughman (Roger)
Username: Roger
Post Number: 144
Posted From: 69.232.73.114
Posted on Wednesday, November 04, 2009 - 6:36 am:
Bill, could you provide more details on the air box and drains. Thanks
Username: Rjlong
Post Number: 1639
Posted From: 67.182.48.162
Posted on Wednesday, November 04, 2009 - 6:44 am:
John & Roger -
Do a search of the archives. Recently Jack Conrad posted a pic of the air box drain canister he built out of PVC pipe.
FWIW & HTH. . .
Username: Roger
Post Number: 145
Posted on Wednesday, November 04, 2009 - 7:04 am:
RJ, I tryed the archives for air box drains and Jack Conrad. I did not find anything about air box drains for last 60 days.
Jim Wallin (Powderseeker01)
Username: Powderseeker01
Post Number: 42
Posted From: 208.68.48.77
Posted on Wednesday, November 04, 2009 - 12:58 pm:
A roof spoiler works great. RV supply houses also generally have a variety of shields made of a heave shadecloth like material that attaches accross the rear bumper and the toad bumper.
Username: Dmd
Post Number: 379
Posted From: 96.232.132.245
Posted on Wednesday, November 04, 2009 - 1:03 pm:
Jack also made a shield for his toad (Jeep cherokee?) that attached to his tow bar. they make commercial ones also, plus the skirt option and its related pros and cons.
Post Number: 304
Posted on Wednesday, November 04, 2009 - 2:39 pm:
Roger
You feed the two tubes from the air boxes into a canister mounted down as low as possible. I used an old fire extingisher. Put a vent on the top of it and a drain in one end with a drain cock on it so you can empty it every once in awhile. The idea is to collect the residue from the tubes and not block the air flow from the air boxes. This stops the oil splatter on the rear of the coach and toad. Hope this helps you.
Bill
Username: Bigrigger
Post Number: 283
Posted on Wednesday, November 04, 2009 - 2:44 pm:
Wow, thanks for all the good ideas. I went looking and found a commercial unit for the drain tubes. Looks like a simple build with some pvc and a few fittings. I wanted something like that anyway as this engine leaves some oil residue where you park. I will leave a link to the unit I am going to copy. Not sure about the need for the fancy breather although some type of vent will be needed.
http://www.walkerairsep.com/pdf/installation/Airbox%20Drain%20Kit%20AJ4120KT.pdf
I may go ahead with a shield of some kind too, might a catch a rock or skunk or something.
Post Number: 959
Posted From: 75.210.213.84
Posted on Wednesday, November 04, 2009 - 3:24 pm:
Interesting subject....
RJL..from what I am reading in the Archives, this "airbox" thing must be peculiar to rear mounted DDs. Question: would something like this work in amidships setup like mine?
I get a LOT of nasty stuff...not wet, (just clings), on the bonnet and rear bumpers. Not sure how this would work.
Insight appreciated! :-)
Thanx
Bob Baldwin (Bob4106)
Username: Bob4106
Post Number: 189
Posted From: 24.74.180.20
Posted on Wednesday, November 04, 2009 - 3:58 pm:
Hi
I bought the walker air box drain kit, and very happy with it. About 85% cleaner on the toad and the back of the bus. The other 10% was the fan drive needed the seal replaced. With the seal replaced on the fan drive, looks like the 5% is just fuel.
Username: Roger
Post Number: 146
Posted on Thursday, November 05, 2009 - 4:22 pm:
I am sorry to harp on this, but I want to know more details. I check the archives back 6 months and could not find it.. The air box you are talking about, is it the conpartment where the squarel cage fans are for the radiator cooling above the engine. MCI-9 8V71. Thanks for all of your help.
Username: Bigrigger
Post Number: 285
Posted on Thursday, November 05, 2009 - 5:25 pm:
Roger the one I have seen and the one I have the link to, mounts on the bottom edge of the engine and the two "slobber tubes" (breathers) run into it. It allows them to breath without the oil running out and being blown over the back of the rig. Then every so often you need to drain it out responsibly and discard it with your other drain oil. Most of the links for these I have found have been for marine applications. I am sure they don't want all that oil in the bilge water. I am making mine from a piece of 3" PVC, capped on the ends with two barbed hose inlets and one petcock on the bottom. I will post a pic when I am done, assuming that it works!
Username: Rjlong
Post Number: 1640
Posted on Thursday, November 05, 2009 - 10:32 pm:
John, Roger & others -
OK, I found the thread, it's over on the BCM BBS. Here's the link, scroll down the page to see the pic's air box drain catch tank Jack built:
http://www.busconversions.com/bbs/index.php?topic=11842.0
FWIW & HTH. . .
Username: Bigrigger
Post Number: 286
Posted on Friday, November 06, 2009 - 2:29 am:
Nice, thanks RJ. That is kinda what I had in mind only mines not so good lol. I guess the breather cap is essential, so I will have to revamp my plans.
Bob MacIsaac (Wildbob24)
Username: Wildbob24
Post Number: 58
Posted From: 67.34.63.44
Posted on Friday, November 06, 2009 - 6:31 am:
Roger,
To answer your question, the air box is the space in the vee of your engine below the blower. It is where the cylinders get the air necessary to support combustion. It tends to collect oil and combustion by-products which need to be drained.
There is a drain on each side of your engine. These drains, on older buses, were originally open to the atmosphere. The installation of a catch can is highly recommended.
Username: Roger
Post Number: 147
Posted on Friday, November 06, 2009 - 6:50 am:
Thanks Guys, and RJ for the link, Now I understand what you all were talking about with the air box drains. I have those two tubs too and they are very messey. Now I know how to fix them. Roger
