Penguin rooftop air Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2009 » July 2009 » Penguin rooftop air « Previous Next »
Andrew Bowey (All2go)
Username: All2go
Post Number: 17
Posted From: 74.202.25.11
Posted on Wednesday, July 01, 2009 - 9:12 pm:
I have two 13,500 btu Dometic Penguin rooftop air units but only one controller. Is there a way to splice them both into the one controller so that they would work in unison? The controller is so old that it is no longer available and the adapter kit is $300, way too expensive for me. The airs work great and so does the controller but on only one air at a time. A picture of the controller is attached here and if anyone has an extra one knocking around or knows where I could get one please let me know. It is so hot I really need a way to control both air units, I do not need zones, just both to work at once.
(Message edited by all2go on July 02, 2009)
Username: John_mc9
Post Number: 938
Posted From: 74.162.82.56
Posted on Thursday, July 02, 2009 - 7:04 am:
"Moor Pmet".
Sounds Danish...?
No wonder you're having a tough time finding one!
Post Number: 548
Posted From: 71.53.155.14
Posted on Thursday, July 02, 2009 - 4:04 pm:
John!!! get a "mirrer" an look at her backwards and see watca git ? Oh could that be my eyes going bad?
Gomer
PS All have a safe holiday and remember what it is for and go to a TEA PARTY.
Username: All2go
Post Number: 18
Posted From: 70.223.70.219
Posted on Thursday, July 02, 2009 - 5:20 pm:
Relief IS needed, does anyone else out there have any insight into Dometic rooftop air controllers? Please?
Post Number: 549
Posted on Thursday, July 02, 2009 - 5:48 pm:
I just found out that someone on line has rebuilt controllers. don't know who but said look up the part on-line???
gomer
FloridaCliff (Floridacracker)
Username: Floridacracker
Post Number: 417
Posted From: 67.8.98.138
Posted on Thursday, July 02, 2009 - 7:05 pm:
Andrew,
You could go with a standard house type control!
At your friendly Hardware or HD, Lowes....Probably under $30....not $300
A cheap one turns the A/C back on...ahhhhhh!
Cliff
(Message edited by floridacracker on July 02, 2009)
Username: John_mc9
Post Number: 941
Posted From: 74.162.78.46
Posted on Friday, July 03, 2009 - 4:27 am:
Try the following places:
http://greensboro.craigslist.org/rvs/1212024539.html
http://www.aaarv.net/duorep.htm
http://www.pplmotorhomes.com/parts/rv-air-conditioner-parts-1.htm
http://www.heartlandowners.org/forum/showthread.php?p=74404
http://www.rvusa.com/forum/mbbs22/forums/thread-view.asp?tid=8682&posts=6
There's a ton, if you Google: duo therm air conditioner thermostat
Username: Dnick85
Post Number: 312
Posted From: 75.197.137.111
Posted on Friday, July 03, 2009 - 11:38 am:
Hi Andrew,
Not that I can see because each board in the upper units, have power supplies
that you would have to isolate or you will burn out both systems.
A better way would be to scavange a selector switch, relays, and thermostat from an old window unit
and adapt them to each upper unit. You would have to know how to remove the board and know which wire are for what to do so...
Seems simple to an A/C guy..
Good Luck
Nick-
