Post Number: 1541 Registered: 12-2000 Posted From: 98.192.173.82
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, May 08, 2009 - 12:49 pm: | |
My thanks to Marty on the Yahoo Flxible bbs for this link: http://www.meritorhvs.com/lodsearch_i.aspx After it comes up, type in SP0600 in the search box in the middle of the page, then follow the link to download the document in .pdf format. It's about 14Mg, so it will take a little while, depending on your internet connection. OK, so what is this? It's the Gabriel Shock Absorber catalog for heavy duty equipment. Lists not only by make/model, but has cross-over references from the OEM number, too. Now you can head down to your friendly parts source armed with the correct number for your coach, be it front, rear or tags. What a shock, eh? FWIW & HTH. . .
Dan West (Utahclaimjumper)
Post Number: 180 Registered: 1-2005 Posted From: 208.66.38.115
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, May 08, 2009 - 2:54 pm: | |
That search yields no results.>>>Dan |
Post Number: 1450 Registered: 10-2003 Posted From: 71.58.110.9
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, May 08, 2009 - 5:06 pm: | |
NAPA has the listings in the Monroe master or commercial vehicle catalog. Big rig shocks are surprisingly cheap and everyone should change out their old ones when working under there. |
Post Number: 490 Registered: 5-2007 Posted From: 64.40.216.17
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, May 08, 2009 - 5:40 pm: | |
It worked for me, found Eagle Motor Coach with out problems, Thanks! ~Paul~ |
Darrell Passer (Orfunautodarrell)
Registered Member Username: Orfunautodarrell
Post Number: 6 Registered: 2-2008 Posted From: 75.108.109.77
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, May 08, 2009 - 7:03 pm: | |
DAN, try SPzero,six,zero,zero SP0600 |
David Guglielmetti (Daveg)
Registered Member Username: Daveg
Post Number: 40 Registered: 2-2009 Posted From: 64.163.110.102
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, May 08, 2009 - 7:21 pm: | |
So how do you know if you need shocks? Take a drive and then slide under your bus and feel the lower body of the shock...if it is hot then it's working. If it is cold or wet/damp as if leaking, it is shot. |
Post Number: 1581 Registered: 12-2000 Posted From: 76.66.19.195
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, May 08, 2009 - 10:23 pm: | |
Or, if they are old and rusty, and you don't know their age, change them out!!! Preventive maintenance means prevention. Know the age of the consumables, otherwise, change them out. Replace parts before they fail. happy coaching! buswarrior |
