Hi this is craigs girlfriend leigh-an... Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2009 » June 2009 » Hi this is craigs girlfriend leigh-ann / question about seperating rooms on bus « Previous Next »
Craig Campbell (Craig_4104012)
Username: Craig_4104012
Post Number: 39
Posted From: 72.61.55.41
Posted on Friday, May 08, 2009 - 4:13 am:
hey everyone, i could use some bus smarts. ok i have been thinking hard about this. we know that we want lots of space in the bus but, we also want dividers of some sort to seperate rooms. i was thinking wide roll up bamboo curtains then i changed my mine. so, ive come up with a few more ideas. 1. rice partitions
2. cloth curtains
3. canvas
i have no idea what would be best any ideas
help thank you
leigh-ann
and craig
Username: Jackconrad
Post Number: 1053
Posted From: 71.3.157.139
Posted on Friday, May 08, 2009 - 1:14 pm:
Leigh-Ann,
Are you wanting dividers that are removable? Most of us put in permanent walls with doors or doorways.
Typically, a bedroom in the back then a permanent wall between the bedroom and the bathroom. Another permanent wall between the bathroom and the front (kitchen/living area) of the bus.
So much depends on how the coach will be used (weekend trips, extended trips, full timing) and how many people will be staying in it (a couple, a family, 2 couples, a group of friends).
Username: Timb
Post Number: 312
Posted From: 66.165.176.62
Posted on Friday, May 08, 2009 - 2:55 pm:
We have a bifold door between the front are and the rear bathroom/bedroom area. There are also accordian doors like the ones used on the stick and staples. Here is one at camping world for $50
http://www.campingworld.com/shopping/item/pleated-bi-fold-door-ivory/7544
Grant Thiessen (Busshawg)
Username: Busshawg
Post Number: 147
Posted From: 206.45.93.160
Posted on Friday, May 08, 2009 - 4:04 pm:
From your heading I thought you were leaving the poor guy!! haha anyway we used regular household doors with walls but Tims idea uses much less space.
David Dulmage (Daved)
Username: Daved
Post Number: 241
Posted From: 142.46.199.30
Posted on Friday, May 08, 2009 - 4:36 pm:
Leigh-Ann,
Lightweight permanent partitions can be easily made and typically will be no more than about 1" to 1-1/4" thick. In our coach I used select pine for the framing and 1/8" luan for the surface material, which was then covered with vinyl wall covering. The partitions have stood up very well.
We laid out our planned design on the floor of the emplty shell with masking tape and also brought a number of the components, including some of the seating, into the bus for a trial fit. In this way we determined that some of the layout, while it looked good on paper, just wasn't comfortable and we adjusted our final layout to make it more suitable. Some folks have mocked-up layouts using carbourd boxes as well.
FWIW
Dave Dulmage
(Message edited by DaveD on May 08, 2009)
Username: Chessie4905
Post Number: 1453
Posted From: 71.58.110.9
Posted on Friday, May 08, 2009 - 10:38 pm:
Some coaches use 3/4 or thicker solid plywood for partitions. They don't use the style used in homes due to limited space. Of course thought has to be given to wiring, etc. as this mostly negates flush wall switches. Or slightly thinner plywood with real wood veneer or Formica attached to it. Also there is plywood available with oak, birch and probably any other veneer already bonded to it. Just stain and seal with desired sealer/ varnish. You really should go to an RV show to get some ideas. Mocking everything up out of cardboard in three dimensions is cheap and although time consuming, can be fun and help avoid the uh-ohs or this ain't gonna work- dang coach is 10 feet too short.
Username: Dmd
Post Number: 315
Posted From: 173.77.212.104
Posted on Saturday, May 09, 2009 - 2:20 am:
We have a canvas partition that fits in a track directly behind the drivers seat all the way across. It has 2 zippers for the doorway in the aisle so when its unzipped you can roll up the door and walk thru or youcan just remove the whole thing. I used it in the winter when living aboard to keep the cold from the doorway and windshield out of the rest of the bus. I left it up in the summer for privacy sometimes. The only down side was it "was" white canvas and someones greasy dirty fingerprints kept getting on it. Probably Dori's. It was made by the canvas store near the marina i worked at. Love it.
Username: John_mc9
Post Number: 894
Posted From: 74.162.82.173
Posted on Saturday, May 09, 2009 - 7:00 am:
Re:
"and someones greasy dirty fingerprints kept getting on it. Probably Dori's. "
Ahh.... so you're into total abstinence too!
Post Number: 1459
Posted on Saturday, May 09, 2009 - 6:39 pm:
No, Dori doesn't follow the posts on here........YET
Username: Vivianellie
Post Number: 242
Posted From: 4.248.48.71
Posted on Saturday, June 06, 2009 - 5:05 am:
Hi Leigh-Ann -
Good talking to you tonight. Okay, I'm a day late and a dollar short, but didn't notice this post until now. I like the bamboo idea to hide 'latitudinal' stuff, like closets, toilet room, etc.
For 'longitudinal' partitions, I'd go with plywood and then, maybe, consider 'pocket' doors. In my case, I went with curtains (fairly heavy) hung on conventional household rods.
Anyway, seeing as Craig is coming by next Monday, he'll get a gander at my layout. Somewhat primitive, but practical and liveable - with refinements slowly progressing.
Anyway, like John (Chessie 4905) says, "You really should go to an RV show to get some ideas." And his cardboard mock-up suggestion? That will save a lot of wasted materials... not to mention labor.
Nellie Wilson
