pipes (198.81.26.174)
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, October 21, 2002 - 4:28 pm: | |
I am trying to mount a fiberglass breast plate (from U know who ) On My 69 05 Eagle,It ALMOST fits.The problem is, if I press it into one place it it pukes out at another place,I have cut it in two verticly in thc center,but still not a good fit. My 05 is a 69 model is it possible that the wind shield area is more of the 01 style ? if I can't make it fit PROPERLY are there any other Ideas?........ Thanks..... Ken. www.pipesusmc.net |
riant (68.116.79.105)
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, October 24, 2002 - 7:06 pm: | |
Ours was the same way had to cut and piece back together with fiberglass. If i hadn't it lookied like a big smiley face. if you have questions e-mail riant@charter.net |
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, October 25, 2002 - 5:24 am: | |
Thanks RIANT... I Gave up on it.I put 1/4 inch wire mesh in a semi circle in between the 2 paralell tubing (Inside) and filled the space with spray foam leaving it recessed ( filed/rasp) about a 1/4 inch and will fill in with fiber glass mat to flush out side. This way it will not interfere with the winshield rubber, foam is 3 inches thick, also acts as insulation and looks better too.... Ken 05 Eagle ... pipesusmc.net |
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, October 25, 2002 - 5:48 am: | |
P.S to "breastplate" The front of my bus is not skinned yet made it easy to do........ |
