john marbury (Jmarbury) (65.100.118.137)
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, October 02, 2002 - 2:07 pm: | |
I'm about ready to cover the rear section of my 4905, I have sprayed thermal coat on the sheet metal. Any ideas on what other layers I should use to block Heat and deaden the engine noise. John |
John Biundo (Jbiundo) (67.112.121.112)
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, October 02, 2002 - 7:32 pm: | |
John, A couple of sites you might check out are: www.soundown.com (note: only 1 "d") www.soundcoat.com I've collected the URLs for checking into later, but haven't used (or really checked out) the products myself. Let us know what you decide on. Good luck, john |
David & Lorna Schinske (Davidschinske) (206.148.180.120)
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, October 11, 2002 - 7:17 pm: | |
Had a former appliance repair man tell us that we should remove the insulation from junked self-cleaning ovens and use. Supposed to have really high R-value. The stuff is usually free if you remove insulation yourself. We are thinking of doing this to whole bus if we can find enough. Lorna |
