Injector size Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2002 » September 2002 » Injector size « Previous Next »
dounan.morton (65.96.80.66)
Posted on Thursday, September 26, 2002 - 2:53 am:
my brown tag N65's don't look like they will fit in my 4 valve head.
it has 75's in it.this is going in an 04, 6-71.
thanks for any feed back
dounan
Luke Bonagura (Lukeatuscoach) (12.90.12.102)
Posted on Thursday, September 26, 2002 - 3:10 am:
Hi Dounan
Unfortunately you are correct.
Your "Straight Body" injectors from your 2-valve head must be replaced with "Off-set" injectors in your new 4-valve head.
So when you order your injectors:
1. State the Size you want.
2. Be sure to mention Off-set injectors.
Hopefully, whoever you talk to will not be too young to know the difference.
I Hope this HELPS!!!!
LUKE at US COACH
Posted on Thursday, September 26, 2002 - 11:06 pm:
luke
much as i feared.
thank you again.
dounan
Tuck-04 (207.144.133.175)
Posted on Friday, September 27, 2002 - 12:27 am:
I changed the injecters in my 2 valve head to the offset type. I had to change the whole rack but it works fine now. I went to N-60s. I have a 4.125 rearend and am getting about 8 mpg and less with the diesel genset running. When I crank my bus the next thing I do is crank the diesel genset.
Tuck-04
