Dennis Tracy (Eagle10)
Registered Member Username: Eagle10
Post Number: 28 Registered: 10-2006 Posted From: 74.75.99.117
Rating: N/A Votes: 0 (Vote!) | | Posted on Tuesday, March 17, 2009 - 9:37 am: | |
I have a 1984 Eagle 10 and the brake lights stopped working on the way home from Florida. When I hit the brakes the King Cruise would not kick off so I shut it off on the switch. The parking brake lights still work but when I hit the brake I have no brake lights. Ideas????? |
Post Number: 671 Registered: 8-2006 Posted From: 74.32.92.133
Rating: N/A Votes: 0 (Vote!) | | Posted on Tuesday, March 17, 2009 - 10:22 am: | |
Dennis, start by checking the switch located in the bottom door and your relay in the upper door. good luck |
Post Number: 842 Registered: 11-2005 Posted From: 208.54.200.73
Rating: N/A Votes: 0 (Vote!) | | Posted on Tuesday, March 17, 2009 - 8:55 pm: | |
Dennis, Your brake light switch isn't working. That's the reason the cruise won't kick off. If your turn signals work that shows the circuit to the brake lights and the bulbs is ok. As posted above, it could also be the relays if you have any. Also check your turn signal switch. This switch is supposed to disconnect your brake lights on one side when in the turn position. Make sure it is dead center, then check the brake lights. |
Jack Campbell (Blue_goose)
Post Number: 123 Registered: 5-2007 Posted From: 71.100.201.35
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, March 18, 2009 - 7:56 am: | |
After going through 3 brake light switches because of the extra lights on the tow and coach I installed a relay that the brake light switch works and that in turn takes the load of the extra lights. The one that I used was like the starter relay on a car. Been working fine for about 15 years now. Jack |
Post Number: 29 Registered: 10-2006 Posted From: 64.223.227.21
Rating: N/A Votes: 0 (Vote!) | | Posted on Thursday, March 19, 2009 - 5:05 pm: | |
Thanks for the ideas. When it gets a little warmer and the snow goes, I will fix it. I will let you know what I find. |
Post Number: 30 Registered: 10-2006 Posted From: 68.238.55.192
Rating: N/A Votes: 0 (Vote!) | | Posted on Sunday, April 19, 2009 - 7:44 pm: | |
Just a quick update on my brake light problem that was solved today. I lost my brake lights on the way back from Florida. I chased wires and fuses for two days without any good results. My bus nut friend and mechanic for many of New Englands bus nuts came over and found the problem. He looked at the wiring diagram on the inside of the electrial panel door and saw that fuse number 29 was the brake light circuit. I took the one from the P.A. circuit and replaced it. Thanks to Mark Willette, I am safely on the road again. Thanks again for the ideas offered when I first posted the problem. I know I should have seen the diagram but it seems just seeing the door itself is getting more difficult. |
