Dometic Propane Fridge Problem Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2008 » November 2008 » Dometic Propane Fridge Problem « Previous Next »
Username: Joe_camper
Post Number: 121
Posted From: 71.239.202.82
Posted on Saturday, November 01, 2008 - 2:19 am:
I have a friend of mine who dropped off his 91 Prevo Country Coach for some suspension repairs and other misc. issues and I have found an issue with the propane fridge.
If it is operating on ac or dc power it works fantastic. When it is on propane it does not get cold enough. I have looked around the heat shield in the back and there is a pilot lit but I have not looked closely at it. Could it possibly be the orifice is dirty or the pilot needs to be turned up.
Any suggestions will be appreciated. Thanks in advance.
Username: Luvrbus
Post Number: 569
Posted From: 74.33.46.157
Posted on Saturday, November 01, 2008 - 2:34 am:
The gas pressure could be low, the flume needs cleaning or could be a problem with the board if it is a eye level control or the thermo coupling does it lite?
Post Number: 123
Posted on Saturday, November 01, 2008 - 2:40 am:
I do have a pilot. I do not think it would work as well as it does on ac & dc the way it does if the flume is dirty but that is a guess.
If the orifice is not dirty and the pilot small is there a way to turn up the pilot?
Post Number: 316
Posted From: 71.55.193.233
Posted on Saturday, November 01, 2008 - 2:57 am:
On this type of refr make sure the switch is making for lp and take and turn the thermostat up and down and listen for a click. If you don't hear a click the t-stat maybe bad. The pilot is small until the t-stat opens the valve to allow more gas in. check for bugs in the gas venturi, spiders and mud dobbers will build a nest and block the orfice also.
gomer
Username: Gusc
Post Number: 758
Posted From: 208.54.200.56
Posted on Saturday, November 01, 2008 - 5:43 am:
Joe,
They don't work well at all on DC, better on AC and best of all on LP.
Username: John_mc9
Post Number: 668
Posted From: 70.157.211.199
Posted on Saturday, November 01, 2008 - 7:11 am:
Dirty orifice, dirt in the chimney, or poor regulation of the gas,
are the common problems. If it works well on AC/DC, the
thermostat's probably fine. Propane usually works the fastest/best
as far as cooling it down.
It does need a good solid flame, though. If all it looks like, is a
small pilot-type flame, it's probably either a dirty jet, or low
regulated pressure.
Try turning all stove burners on (lit of course), and make sure
the gas is flowing well enough. Doing that, will usually purge
any air out that may have accumulated from sitting.
(that's an old RVrs trick) (uhh, and a RV shop's trick)
A good source of info:
http://www.rvmobile.com/
(Message edited by john_mc9 on November 01, 2008)
Username: Texasborderdude
Post Number: 150
Posted From: 75.209.215.237
Posted on Saturday, November 01, 2008 - 3:36 pm:
I chased a similar problem about a year ago. Gotta check the pressure at the fridge. Can't rely on the range, water heater pressure, etc. A new regulator fixed my problem; but still works better on ac (which it shouldn't) Good luck!
dg
Username: Jackconrad
Post Number: 857
Posted From: 173.116.71.199
Posted on Saturday, November 01, 2008 - 5:29 pm:
I had a friend with this problem on his refrigerator (I don't remember the brand), but we found a large accululation of rust around the LP orifice. We vacumed the rust, tapped on the "chimmney" a few times to dislodge more rust, vacumed again and fixed the problem
Post Number: 126
Posted on Sunday, November 02, 2008 - 1:47 am:
Well after further investigation I am going to replace the regulator. Everything else checks out OK. The pilot looks large enough but I am guessing. Took it apart, clean as a whistle.
I'll keep you posted.
Username: Niles500
Post Number: 877
Posted From: 71.180.124.221
Posted on Sunday, November 02, 2008 - 1:56 am:
That's a smart first move - I know Doyle would rather have changed his out first before paying the long dollar at RV Medic -
Doyle - Glad to hear that it at least did the job!
Username: George_mc6
Post Number: 605
Posted From: 207.231.75.253
Posted on Sunday, November 02, 2008 - 3:20 am:
Joe,
A thought on this, and to echo Gus's comment.
"They don't work well on DC, better on AC, and best on propane." The reason they do that is a direct result of the amount heat applied to the heated portion of the refrigeration system. (In an absorption type of refrigeration system, the more heat, the more cooling.)
Everyone else has pretty much figured it out already, you don't have enough heat on propane, and I agree. My only additional suggestion is to check the flame size before replacing the regulator. A lot of these refrigerators don't actually have a pilot, they just vary the flame between high and low according to the thermostat. That's why they freeze stuff in cool weather, the fridge is capable of freezing at low fire with low ambient temperature.
So, look at somebody else's fridge, and see if the fire switches from high to low with the stat before changing the reg? Or if you have a manometer, the pressure must read at least 11 inches of water column on the outlet side of the reg with the fridge and at least one stove burner lit. It may [have to read] 13" with absolutely nothing on, to get 11" under load, which you have to have to get proper output and performance.
I assume this fridge needs DC for control, and you have it?
If your flame doesn't change size, I feel you have a control problem, not a propane supply problem?
Good luck, and happy hunting!
George
Username: Gusc
Post Number: 759
Posted From: 208.54.200.69
Posted on Sunday, November 02, 2008 - 4:31 am:
Joe,
Please let us know what you find out.
The only problem I ever had was a failed ingiter board. Simple to replace but expensive to buy.
George,
Mine won't work at all on any type of power if there is no DC.
Post Number: 128
Posted on Tuesday, November 04, 2008 - 12:18 am:
It was that regulator. I went out and got a new 2-stage and it was 17 bucks.
I wish all the fixes were that cheep and easy.
Thanks for the suggestions.
Username: Gusc
Post Number: 765
Posted From: 208.54.200.15
Posted on Thursday, November 06, 2008 - 1:35 am:
Joe,
Thanks, those are the kind of repairs I like!
