Replacing my 6-71 Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2002 » July 2002 » Replacing my 6-71 « Previous Next »
dounanpm (152.163.188.227)
Posted on Friday, July 12, 2002 - 1:49 am:
can anyonne tell me if i can use a 6-71 with an automatic from a city bus,in my 4104 without changing the rearend ? i've got a 3:83 rear.
dounan
Posted on Friday, July 12, 2002 - 2:11 am:
Altho I've never done it, but knowing GM's history of shared componentry, I wouldn't be surprised if the powertrain out of an "Old Look" GM transit would fit with little modification.
(The "Old Look" transits were built from the late 1940's thru 1959/60, during the same period as the 4104.)
Getting parts for an Old Look auto trans will be an interesting challenge. . .
HTH,
RJ
PD4106-2784
Fresno CA
Dallas (216.98.68.82)
Posted on Friday, July 12, 2002 - 11:54 am:
I'm not sure if you would want to do that. A bunch of the old look transmissions were 2 speed hydraulics, (spicer model 90 and 91), but if you really want to do it, I've got my 3610 up for sale, new engine and transmission rebuild less than 3k miles.Contact me off the board.
Truth in advertising tells me to say that you'ld probably be much happier with a VS or something newer.
Dallas
Posted on Friday, July 12, 2002 - 11:06 pm:
duh, i meant to say my ratio is 4.125
i was told that a transit package with auto could go in but the oil pan and hyd fan need to be changed.
i pulled the trans . off today , the flywheel p-plate and clutch fell off. all the bolts had snapped about 1/2 -3/4 inches in the crank .
its all pretty hammered in there.
i figure it will be just as well to swap now.
dounan
