Post Number: 1420 Registered: 12-2000 Posted From: 67.181.166.160
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, September 12, 2008 - 4:34 am: | |
Since my coach is out of commission at the moment, I'd like some help from fellow 4106 owners on a simple little research project. With the coach on pavement, and the suspension aired up for normal street operation, I'd like to know the measurement in inches from the small lip on the chassis at the rear corner of the driver's window (just in front of the "D" window) to the ground. I'll let everyone know the results of my little project after I get some responses. Thanks, guys!
Post Number: 463 Registered: 10-2006 Posted From: 208.100.193.179
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, September 12, 2008 - 11:49 am: | |
RJ , Contrary to common opinion , even the Sportscar of Coaches wont leap tall buildings! Currently not parked on pavement ,but will measure when I can. Cant the above bumper rubber measure as used to set air bag height work for you? FF |
Dan West (Utahclaimjumper)
Post Number: 103 Registered: 1-2005 Posted From: 208.66.38.115
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, September 12, 2008 - 3:26 pm: | |
65" >>>Dan |
Tony Gojenola (Akbusnut)
Registered Member Username: Akbusnut
Post Number: 28 Registered: 11-2006 Posted From: 208.98.151.220
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, September 12, 2008 - 6:28 pm: | |
Post Number: 1421 Registered: 12-2000 Posted From: 67.181.166.160
Rating: N/A Votes: 0 (Vote!) | | Posted on Sunday, September 14, 2008 - 7:39 am: | |
Thanks, guys, for your help. I was curious to know how much difference there is between the 4106 and the Buffalos in terms of driver's seat height from the ground. Depending on tires and ride height adjustment, it looks like the '06 driver sits about 6" higher, and both sit slightly higher than a Scenicruiser operator. Again, I appreciate my fellow busnut's assistance, thanks!! FWIW. . .
