Trailer hitch for eagle Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2008 » August 2008 » Trailer hitch for eagle « Previous Next »
c.w Van Hagen (Van)
Username: Van
Post Number: 22
Posted From: 72.193.19.183
Posted on Wednesday, July 23, 2008 - 8:52 pm:
does any body have pics of an installed reciever hitch on an eagle need to install one on my model 15,could use some direction and advice
Bill 340 (Bill_340)
Username: Bill_340
Post Number: 65
Posted From: 75.249.35.210
Posted on Thursday, July 24, 2008 - 4:32 pm:
Bolt across the engine cradle from underside, then center the reciever between the cradle frame, that creates a slight off set hitch allowing you to see the edge of your tow at a glance, tows strait had one for years that way.
Username: Luvrbus
Post Number: 475
Posted From: 71.30.179.250
Posted on Thursday, July 24, 2008 - 4:59 pm:
CW, mine has 2x2 square tubing between the engine rails with 5/8 plate welded on top of the tubing hole drilled in the plate bolted to the top with 2- 3/4 bolts where the last holes are in the engine rails and a 5/8 2 inch wide strap tied to the front engine cradle mount with 2x2 piece of angle iron welded to the cradle and a 1/2 inch bolt 3 bolts to remove the hitch.Don't do like I did the first time and line it up with the engine.I have photos but not smart enough to post them
(Message edited by luvrbus on July 24, 2008)
Username: Luvrbus
Post Number: 476
Posted on Thursday, July 24, 2008 - 5:01 pm:
CW, mine has 2x2 square tubing between the engine rails with 5/8 plate on top bolted to the top of the engine rail with 2 3/4 bolts where the last holes are in the engine rails and a 5/8 2 inch wide strap tied to the front engine mount with a plate and a 1/2 inch bolt 3 bolts to remove the hitch.Don't do like I did the first time and line it up with the engine.I have photos but not smart enough to post them
c.w Van Hagen (Van)
Username: Van
Post Number: 32
Posted on Friday, July 25, 2008 - 3:44 pm:
thanx,we will have to get together when you get back can probably help ya there
larry currier (Larryc)
Username: Larryc
Post Number: 190
Posted From: 207.200.116.13
Posted on Monday, July 28, 2008 - 4:07 am:
A hitch on an Eagle usually requires a change in the exhaust system. Most end up dumping behind the pass side drivers.
Robert Ward (Augusta)
Username: Augusta
Post Number: 1
Posted From: 72.202.138.252
Posted on Friday, August 01, 2008 - 10:52 pm:
Don't forget to unhook your electronics. I found out the hard way. $1500 mistake. reward
