WIRING LABELS Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2001 » January 2001 » WIRING LABELS « Previous Next »
Steve Fessenden (63.27.88.87)
Posted on Monday, January 29, 2001 - 10:49 pm:
I wanted to label my new battery cables permanently and neatly. My son suggested waterproof address labels printed on a laser printer (the ink waterproof).
I just printed them up and they look great.
Staples had them: Avery #5510 Weatherproof Laser Labels, 1" X 2 5/8", 30 per sheet. $25.99 for 25 sheets, 750 labels. Less than 3 cents per label. Less when you print many times on one label. My "12 volt", "24 volt" and "115 volt" labels are printed 12 to a label and cut.
Hope this helps someone else. SF
Chuck Harris PD4104 (207.172.119.28)
Posted on Monday, January 29, 2001 - 11:00 pm:
Steve,
What I have always done, is print the labels
in a scroll on my laser printer:
12 VOLT
12 VOLT
12 VOLT
12 VOLT
And roll the scroll around the wire, and put
a piece of clear heatshrink tubing over the
label.
I have delivered cable assemblies to the military
that I did this way.
-Chuck
George Myers (12.85.14.79)
Posted on Tuesday, January 30, 2001 - 4:26 am:
You can water proff regular labels by spraying them with a clear paint of some kind, such as Krylon clear. Do not us a shellac as the ink will run, but almost any solvent other than water or alcohol will work well. We us this to water proof mailing labels for mailing.
