Ross power steering parts Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2008 » July 2008 » Ross power steering parts « Previous Next »
Username: Dougthebonifiedbusnut
Post Number: 53
Posted From: 75.69.223.64
Posted on Tuesday, June 24, 2008 - 2:46 am:
Hey All,
The power steering to the left has diminished almost to nill. I'm guessing it is the hydraulic cylendar that pushes and pulls the Tie Rod. anybody know were to get a new cylendar along with new boots.
Username: Pvcces
Post Number: 1214
Posted From: 65.74.72.93
Posted on Tuesday, June 24, 2008 - 3:33 am:
Doug, that can just as easily be the control valve. One way to figure out if it is clearances in the valve or cylinder is to compare the effort at idle and at fast idle.
If the idle speed makes a lot of difference, then I would suspect wear. If it doesn't, then it may be something broken.
For what it's worth.
Suncatcher
Ketchikan, Alaska
larry currier (Larryc)
Username: Larryc
Post Number: 183
Posted From: 207.200.116.13
Posted on Friday, June 27, 2008 - 5:27 am:
Bleed it. Make sure its full of the right stuff. Mine loved the Lucas stuff for steering boxes.
Make sure the steering box is not falling off.
Is something loose or falling off the steering arm? Did the nut that holds the steering arm to the steering box come loose?
Michael W. Haworth (57fitzjohn)
Username: 57fitzjohn
Post Number: 18
Posted From: 70.141.108.164
Posted on Sunday, July 13, 2008 - 9:30 am:
Hey Doug!
I'd be interested to know how you come out on your steering. I've got the old Ross Cam&Lever setup on mine too. Seems to have an intermittent shudder thru the power assist when going around corners, but only if you turn the wheel faster than it likes. (tempermental old bitch!)
