Rear end Questions? Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2002 » May 2002 » Rear end Questions? « Previous Next »
John Morrison (Jomorisn) (64.12.107.54)
Posted on Tuesday, May 28, 2002 - 2:42 am:
I own a 1966 MCI 5A and was wondering what rear end s fit this coach is it just MCI ? I have heard eagles have the same type rears any and all info would be great .
Thanks John
Bus Jock (152.163.205.69)
Posted on Friday, May 31, 2002 - 5:37 pm:
John,
The rear end is a Rockwell. Most good truck gear houses will be able to rebuild it for you. I had ours done recently. They replaced all of the gears and bearings. Cost was about $2800 not counting labor to install. Only one gear was broken, but all magnafluxed with small cracks in them. You can get a used Diff unit for less but it probably won't pass magnaflux, although it may run many miles.
Jock Fugitt
Bus Jock (205.188.201.142)
Posted on Saturday, June 01, 2002 - 12:47 am:
John,
I forgot to mention that the rockwell drop box differential is available is several ratios. Be sure to get the right one. I think it is 3.36:1 for the good gearing. the MC5-C Saudi busses had a very low gearing for the 6-71 engine. will limit top speed to about 65. My books are across town with the bus right now, but next week when I get the bus back home, I will check for sure on the ratio.
Jock Fugitt
