Ross Carlisle (Ross) (216.107.197.12)
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, May 08, 2002 - 2:14 am: | |
On an MC9, which side of the bus has left hand lugs and which side has right hand lugs? Thanks....Ross |
dana23 (152.163.206.199)
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, May 08, 2002 - 3:05 am: | |
i found out the hard way driver side is left handed and does anyone know about the holes in the wheel do the 5 holes go in front and the 2 hole goe for the tag axelcaue 1 side they have the 2 up front and the 5 in the back or does it matter |
Earl-8-Ky (209.42.180.121)
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, May 08, 2002 - 4:55 am: | |
You have some bus wheels and some truck wheels. Bus wheels are 5 hole. |
Luke Bonagura (Lukeatuscoach) (67.235.168.161)
Rating: N/A Votes: 0 (Vote!) | | Posted on Wednesday, May 08, 2002 - 2:52 pm: | |
Hi Ross: When determining left & right on your coach, sit in the drivers seat. You are siting on the LEFT side & the entrance door is the RIGHT side. With regard to your Studs: The L/H are on your side & the R/H are on the door side. Most stud manufacturers stamp an R or L in the end of the stud & unless covered by 50 coats of paint are usually visible. I Hope this HELPS!!!! LUKE at US COACH |
Jim Nelson (166.90.108.147)
Rating: N/A Votes: 0 (Vote!) | | Posted on Monday, May 13, 2002 - 2:22 am: | |
MCI includes both 5-hole and 2-hole rims in the parts book, and they will mount on any axle. The 5-hole rims are easier to use on the drive axle, since you need to do less work to line up the valve stems on the duals, but the 2-hole rims are just fine for the bus. |
