6V92 Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2002 » May 2002 » 6V92 « Previous Next »
Blake (206.191.1.217)
Posted on Thursday, May 02, 2002 - 4:42 pm:
What injectors, cams, turbo, pistons, cylinder sleeves, etc. are required to make a 6V92 into a true 350 HP engine? Are there any web sites dealing with making horsepower from a 92 series Detroit?
Blake
Jim Stacy (12.87.110.247)
Posted on Friday, May 03, 2002 - 12:45 am:
All "normal" 6V92TA's are advanced timing and use the same cam and pistons. All horsepower changes are made by changing the injectors and turbo. Everything else stays the same. I don't have my book available but it would require G90 injectors and a turbo with an R/A ratio near 1.0 if I remember what we did to mine 4 years ago. Geoff probably has that info as he did his about the same time.
Jim Stacy
Jim Nelson (65.56.69.93)
Posted on Monday, May 06, 2002 - 2:03 am:
However, those engines were never certified for parlor coach or transit applications by the EPA, and you could get into trouble in California or any other area that has smog inspections. That is a whole ball of wax that I would avoid, personally.
Scott Whitney (24.205.238.126)
Posted on Monday, May 06, 2002 - 6:00 pm:
Does CA have somg inspections for diesels? I've never had to have my bus inspected. Gas vehicles newer than 1973, however, do. But my bus is 1974, no inpsection reqd. - AFIK.
Scott
Johnny (63.159.212.149)
Posted on Wednesday, May 08, 2002 - 8:53 am:
Most places have high-GVWR vehicles, diesels, or both exempt. The cutoff here is 8500, & all diesels are exempt. Nice!
As long as it runs clean, I don't see how they'd even notice injectors, short of a physical teardown.
