Post Number: 584 Registered: 7-2006 Posted From: 66.217.106.199
Rating: N/A Votes: 0 (Vote!) | | Posted on Friday, February 15, 2008 - 7:24 am: | |
The leveling valves and air lines run across, under the front edge. I wouldn't go sealing up that engine access cover, if I were you! Like Ed mentioned, you can peek through the access cover, or look underneath, from either side rear door, to locate other things you may not want to puncture. If that's a standard RV type gas/elec fridge, you're going to need a rear access door for it... tough to do, mounted back there.. |
